ABS Light on with multiple issues
Old Jun 25, 2004 | 03:07 PM
alan35's Avatar
alan35
Smile ABS Light on with multiple issues
Hi,
I have a 2000 Ranger XLT V6 3.0 Engine 2 Wheel Drive with 4 wheel ABS.
I had check engine light come on a few days ago. I had a friend pull code and it was 0113. That calls out an IAT sensor. No problem, I am going to autozone to pick up. I just had my truck in for 4 tires and a wheel alignment.
When mechanic came back he said the ABS light is on. He put it on rack and checked for a loose wire and then blew out front sensors. Light went out for 10 minutes and then returned. I have been reading the threads and I don't have sysmptoms of speedo problems or rough shifting. Everything seems normal except the check engine and the ABS light. Should I fix the first problem and then proceed to the next. Any info appreciated.
Old Jun 25, 2004 | 08:33 PM
Ken00's Avatar
Ken00
No reason not to correct the 0113. Have your friend pull the codes again and see if you have any more codes. What do you mean "he blew out the front sensors"?
Old Jun 25, 2004 | 08:42 PM
alan35's Avatar
alan35
Ken,
What I mean is he used compressed air and blew out the front ABS sensors by the wheels in case the sensors had some dirt or magnetic particles on them.
Alan
Old Jun 25, 2004 | 09:11 PM
Ken00's Avatar
Ken00
OK, go with the codes and a visual inspection for damage, kind of funny it happen after they put tires on, maybe they bumped something.
Old Jun 27, 2004 | 10:29 AM
alan35's Avatar
alan35
Ken,
I have changed the IAT sensor for code 0113 and that was ok. There are no more codes in the computer. So now I have the ABS light on. I have visually inspected the two sensors on each front wheel. Everything seems to be intact. I have removed the negative battery terminal for 1/2 hour. Light still on.
Old Jun 27, 2004 | 06:46 PM
fifteen+'s Avatar
fifteen+
get the codes from the abs module to point you in the right direction.This could be a number of concerns.If the code is for the frt. sensors they both should be replaced according to ford.
Old Jun 27, 2004 | 08:55 PM
Ken00's Avatar
Ken00
Are you sure that the scanner can pull the ABS codes? Are you sure it's 4 wheel ABS, not RABS?
Old Jun 28, 2004 | 06:30 PM
alan35's Avatar
alan35
I have access only to a OBD scanner for check engine codes. Are we talking about the same scanner. If so where is the ABS module and does it have the same connector. Yes this is 4 wheel ABS. Under the hood the by the battery is the ABS box with 5 lines going to it.
Alan
Old Jun 28, 2004 | 11:27 PM
fifteen+'s Avatar
fifteen+
you do use the same diagnostic port under the dash. I only have used the ford scanners, but my understanding is that snap-on scanners can get these codes as well. You may want to see someone who can get the codes for you.
Old Jun 29, 2004 | 06:52 AM
pawpaw's Avatar
pawpaw
Run this puppy by the likes of Advance Auto or AutoZone, for a no cost scan.
The one's in my area use the Actron CP9145 scanner which can pull your codes. You could call ahead & see if the particular store's sanner will pull your codes.
Old Jun 29, 2004 | 09:01 PM
Ken00's Avatar
Ken00
I'm just wondering if the scanner he has only pulls generic codes and the ABS codes might be Ford specific.
Old Jun 30, 2004 | 06:00 PM
alan35's Avatar
alan35
Ken,
I have called around some of the autozones and other parts places and the only thing that they can check for is check engine codes. From what I am hearing I need to get Ford to check for the ABS codes. Right now I am driving the truck with no problems other than the light being on. I need to find out how much the 2 front sensors are. It may be cheaper to replace than have Ford diagnose it. In a few weeks my friend who does the major work on the truck, is going to replace the brake fluid and put rear brakes on, only because I am nearing 90,000 miles and I have the brakes in my garage. We shall tackle the problem then. If we fix it, I will definitely let you know.
Thanks,
Alan
Old Jul 1, 2004 | 12:19 PM
Ken00's Avatar
Ken00
I would expect some of the more advanced scanners would do the ABS codes, maybe a local shop would be cheaper than the dealer. Would hate to install new parts that are not the problem.
bockusd
Oct 14, 2009 11:53 AM
cratemotor
17
Dec 3, 2007 12:23 PM
THE KING
1978 - 1996 Big Bronco
May 31, 2007 08:13 PM
ROKNZRX
May 18, 2005 10:13 AM
