99 mazda b-3000
Old Jun 25, 2004 | 06:59 PM
mr.mazda's Avatar
mr.mazda
Question 99 mazda b-3000
hi all i need info on my 1999 mazda b3000 with 3.0 L 4x4 with automatic transmission.i just got back from a trip and had to end up towing a u-haul weighing about 1500 lbs.while i was driving my kid flipped my 4x4 switch into 4x4 high.while i was towing and i switched back to 2wd as fast as humanly possible.i started having problems with the truck, my speedometer started fluctuating i stopped the truck and restarted it and everything seemed o.k. then i went out to go to work and now the speedometer want read at all,my abs light is staying on and my overdrive light is blinking on and off,it is also shifting horribly like the transmission doesn't want to shift gears.
i would appreciate any help,
mr mazda
Old Jun 25, 2004 | 07:04 PM
ranger pat's Avatar
ranger pat
Veteran: Navy
It sounds like a failure of the vehicle speed sensor that is located on top of the rear axle. That provides input to the speedometer, cruise control, ABS and transmission. Easy to change, a two wire connector and one bolt retainer hold down.
Old Jun 25, 2004 | 07:09 PM
mr.mazda's Avatar
mr.mazda
Red face thank you
i pray your right
Old Jun 25, 2004 | 07:19 PM
mr.mazda's Avatar
mr.mazda
did shifting to 4 wheel drive while towing cause it to go out?
Old Jun 25, 2004 | 09:44 PM
hreed's Avatar
hreed
Probably not. I am not a big believer in coincedences, but the first thing to check is the VSS. It may have failed at the same time (or close to it). Your problem sounds like a VSS. Keep us posted.
Old Jun 26, 2004 | 07:09 AM
mr.mazda's Avatar
mr.mazda
where can you buy a vehicle speed sensor?
Old Jun 26, 2004 | 08:24 AM
Bob Ayers's Avatar
Bob Ayers
I bought mine from Ford, for about $23. I have heard that NAPA also carries the speed sensors....
I agree, your problem is the speed sensor in the rear diff.,
and I don't think it had anything to the 4X4 button being pressed.
Old Jun 29, 2004 | 07:26 PM
mr.mazda's Avatar
mr.mazda
the part i took out of the rear axle doesn't look like the replacement i got.
please help
Old Jun 29, 2004 | 09:11 PM
Ken00's Avatar
Ken00
They may have given you an output shaft sensor, take the VSS with you to the parts store.
Old Jun 30, 2004 | 01:55 PM
mr.mazda's Avatar
mr.mazda
i found out the 1999 mazda b3000 does not have a vehicle speed sensor the vss is only on 1997 and earlier models,but there is some sort of sensor there what is it?
any help would be appreciated.
Old Jun 30, 2004 | 04:06 PM
Ken00's Avatar
Ken00
Who told you that, I have one on mine and Bob Ayers just replaced his and he has a 99 3.0.
Old Jun 30, 2004 | 09:47 PM
mr.mazda's Avatar
mr.mazda
my haynes book, the way they make it out is that it is a speed sensor.it's wasn't classified as a vss.i found out from the parts guy at the mazda place he
said that the 99 mazda has two speed sensors on the front at each tire or around there and one on the back at the case.i did do as you suggested and took the sensor out and took the part to mazda and got the right one(and it was a pain to get out,well for me anyway)i replaced the one i got and it runs like a champ.i want to thank you guys for the help all of you.i really appreciate it.yall were right thank you very much.
mr.mazda(chris)
Old Jul 1, 2004 | 12:25 PM
Ken00's Avatar
Ken00
Glad to hear you got things fixed Chris!!
b-series
Jun 27, 2015 08:48 AM
wburge
Mar 30, 2015 11:54 AM
Jana54859
Sep 19, 2014 12:48 PM
Jason302
32
Jan 12, 2014 11:24 AM
johnpatnc
Jan 12, 2005 07:11 PM
