DPFE Sensor
Old Sep 2, 2002 | 09:08 PM
AnthonySoos's Avatar
AnthonySoos
DPFE Sensor
Can I check the output voltage from the DPFE sensor with a voltmeter? I have a 96 F150 with the check engine light pointing to this sensor. I feel pulsating pressure at both input and reference lines. I have 5 volts reference input but do not have the specs on what the out should be.
Thenks for any help,
Anthony
Old Nov 8, 2002 | 10:02 PM
lself62's Avatar
lself62
DPFE Sensor
I just went through this. Cold you should have 5v +/-? on one side and almost nothing on the other. After reaching 113 degrees there should be 5v on both sides.
The pulsing vacume is right. The way it was explained to me . . . these don't operate on strength (inches) of vacume, they operate on frequecy. Faster or longer (?) pulses open the EGR valve more.
Hope this isn't way to late. . .
Old Nov 8, 2002 | 10:10 PM
wbandyjr's Avatar
wbandyjr
DPFE Sensor
OUTERORBITER
1983 - 2012 Ranger & B-Series
Nov 1, 2008 03:25 PM
ajm859830
1997 - 2003 F150
May 28, 2008 09:09 PM
Powerkleen
4 Cylinder Engines
Aug 11, 2006 07:34 AM
ericcochran
Jul 10, 2005 06:15 PM
rwsupra
3.0L V6
Jun 19, 2004 01:16 PM
