EGR High input/ P1401
Old Jul 10, 2005 | 05:43 PM
ericcochran's Avatar
ericcochran
I need some help! I had my check engine light come on and decided to buy a OBD II code reader to find out what it was. It gave me a reading of P1401. I have replaced the DPFE sensor, the EGR valve, and the EVR. What else can I do?
I heard somewhere that a new DPFE has to be either metal or plastic and they are not interchangable?
Any help would be greatly appreciated.
Old Jul 10, 2005 | 06:15 PM
Rockledge's Avatar
Rockledge
P1401 - DPFE Sensor Circuit High Voltage Detected
Welcome to FTE!
You might have to look over the circuits, the problem may not be mechanical, but instead, electrical.
The EGR monitor checks the DPFE sensor signal to the PCM for high voltage. The test fails when the average voltage to the PCM goes to a voltage greater than the maximum calibrated value.
Possible causes:
l Damaged DPFE sensor
l DPFE SIG circuit open
l VREF short to PWR
l DPFE SIG circuit short to PWR
l SIG RTN circuit open
l Damaged PCM
On some OBD-II systems, plugged hoses running from the DPFE to the EGR tube will also set off a P1401.
Hope this helps, good luck with the troubleshooting.
f150-az
1997 - 2003 F150
53
Aug 2, 2016 06:18 PM
207peas
Apr 27, 2015 08:27 PM
asurber
1997 - 2003 F150
Jul 17, 2010 02:23 PM
piedmont
Aug 16, 2007 10:07 AM
blackwidow1
18
Jun 7, 2007 06:50 AM
