Guys what the heck is a sout connector. I want to adjust me timming and it says to desconnect the SPOUT connector first. WHAT is it and where is it. thanks Ryan
Post more specifics such as what year what engine etc. Mine is a 95 f150 inline six and is on the inside fender well next to ignition conrol module. Yours may be close to the distributor.
Look for the wiring harness coming out from your distributer,,, it will be a small relay thats sticking out from the wiring. it is stand alone and not plugged into anything looks like it is capped off. Pull that cap out .then adjust your timing and then reset your cpu .
The spout connector "looks" like a cap. You have to remove it to keep the engine from advancing the timing while setting the dizzy. If yours is missing, it will cause idle and driveability concerns
Ryan, is your tfi (control module) mounted on the firewall? On my 90 f150 w/ 302, it is on the tfi harness a few inches from the distributor. I think on 91 or 92 and later, they relocated the TFI to the firewall to keep it cooler. I am guessing that the spout would be near the brake booster on those models.
To everyone that provided much needed insight here THANK YOU! All the advice helped me learn more about my truck and saved alot of money and hassle. Thanks again! Ryan
