Cat Bad? P0420 code
Old Jun 21, 2004 | 02:43 PM
DoraDexplora's Avatar
DoraDexplora
Cat Bad? P0420 code
I have a 96 Explorer (6 cyl 110k miles) with a check engine light on, Pep Boys says the cat is going bad but my mechanic says its the O2 sensor. Any way to figure out who is right?
Much appreciated
Old Jun 21, 2004 | 03:03 PM
ranger88a's Avatar
ranger88a
P0420 is a catalyst below efficiency code. You probably have a cat going bad. The code tells me the sensor works, and that the cat doesn't do it's job. I have however had a problem with some aftermarket cats, they don't seem to do the job well. Fords cats work, but are very expensive. Try looking for a reputable exhaust dealer who will stand behind their work.
Old Jun 21, 2004 | 04:58 PM
87 XLT's Avatar
87 XLT
I agree, sounds like a bad cat.
Old Jun 22, 2004 | 07:51 AM
DoraDexplora
Will do, Monroe makes a bolt on Cat for $500, half what Ford wants for theirs.
Thanks for the direction.
Old Jun 30, 2004 | 05:47 PM
91-Exploder's Avatar
91-Exploder
There is a TSB available for this problem I had it on my 96' exploder
PCM - MIL ON DTC P0420 Stored in Memory TSB 00-26-4
You need to have your PCM recalibrated with a updated calibration file
the one the TSB recommends for 49 state cars is 6-58B-R10
This is a dealer job should be about $75-100 Much cheaper than a new cat
if this does not fix the problem you will need a new cat
Old Nov 22, 2004 | 07:04 PM
jbenazzi's Avatar
jbenazzi
I have found the same thing . . .
I spoke with a Ford mechanic this morning . . . I told him my 1996 Explorer (116K miles) was showing the P0420 "catalyst below efficiency" code. I asked him what that meant (not mentioning that I had researched it here). He told me that it probably meant that I needed a new cat. I then told him that I had heard about the technical service bulletin from Ford about recalibrating the Powertrain Control Module (PCM). He had never heard of the TSB but when he came back he told me, "you definitely do not want to replace your cat, you DEFINITELY want to have your PCM recalibrated first." He said that, more than likely, he thought the recalibration would solve the problem (I really really really hope he is right).
Old Nov 22, 2004 | 11:07 PM
quadrazer's Avatar
quadrazer
Tsb
Any idea what years this TSB covers? Just wonder if I should have the update done on my 98 Explorer.
Old Nov 23, 2004 | 07:23 AM
91-Exploder
The TSB appears to be generic for Gen II X's the actual TSB has about 35 PCM's listed it came out in 2000 so I would imagine that your 98 would be covered. Found this one because dealer told me I needed new cat and O2 sensor (x4) for $2200!!!. At the time I had a chance to buy a Snap On MT2500 with the troubleshooter. Tool lust won out and the first thing I found upon scanning was the TSB for the cat this saved me about $1700 bucks. A good scan tool is definitely worth the money.
KNOWLEDGE IS POWER!
Old Nov 23, 2004 | 09:28 AM
Ladder's Avatar
Ladder
Have a look:
http://www.alldata.com/index.html
infinite-foamies
Apr 21, 2014 06:59 PM
Pikachu
Feb 10, 2010 10:27 AM
BPofMD
Oct 20, 2008 11:18 AM
BPofMD
Nov 28, 2007 10:17 AM
westladog
20
Dec 27, 2004 03:14 AM
