93 explorer wont start
Old Nov 22, 2004 | 06:06 PM
mrblottokid's Avatar
mrblottokid
I have a 93 explorer in my drive way that wont start. I notice that when I try to start it theres a click right where the clynoid is so I changed it but it didnt help I also thought it might be the battery but I tryed to jump it and its still the same any help would be appriciated thanks.
Old Nov 22, 2004 | 09:17 PM
Bashman's Avatar
Bashman
Check to make sure all your connections are clean and tight, but usually a click followed by nothing means your solenoid is working but your starter is pooched.
Old Nov 22, 2004 | 10:23 PM
JerrySimm's Avatar
JerrySimm
Also, make sure your battery is charged. I have seen batteries with 1 or 2 dead cells that would not jump. Check the battery voltage when not loaded, and when trying to start. Unloaded should be just over 12 volts, and when trying to start should be over 10 volts.
Old Nov 23, 2004 | 01:22 PM
99Xplr's Avatar
99Xplr
There is a common problem with the 1st gen X's.... the main cable that runs from the selenoid on the passenger side fender down to the starter. I had the same problem with my 92... one day it just would not start. Never noticed a problem before the... so it was really quite baffeling. When my mechanic checked the wire.. there was over a 300ohm resistance on it... (it shouldn't be anything more then about a .5 ohm). Once the cable was replaced everything was fine.
Old Nov 23, 2004 | 02:26 PM
sjwoody's Avatar
sjwoody
Ditto on the battery cable feed to the starter. My 92 had the same problem. The cable looked good on the outside but had high resistance on the inside. Try a jumper cable from the solenoid down to the starter, bypassing the existing cable...you don't even need to disconnect anything.
Good luck
tayababy24
Feb 23, 2013 01:52 PM
TSwiG
Aug 29, 2006 05:09 AM
shortstack567
Feb 22, 2005 01:28 PM
vicmustaine
Jan 17, 2005 08:29 AM
TOMKLU
Apr 14, 2004 01:52 PM
