98 Explorer Electrical Problem
Old Jun 21, 2004 | 11:39 AM
ltng7679's Avatar
ltng7679
I've got a 98 Explorer with a 4.0 SOHV and 120K miles. It seems that my charging system isn't working - the battery holds a charge but after use it gets drained. I haven't hooked the voltmeter to it yet though. Does the charging system on these trucks have a separate voltage regulator or is it built into the alternator? If I have to replace the alternator is there anything else besides the serpentine belt I should think about doing - idlers, water pump ....
Thanks in advance for any advice.
Old Jun 21, 2004 | 01:56 PM
87 XLT's Avatar
87 XLT
Check the voltage at the battery with your voltmeter, should be approx 14 volts with engine idling. If you are good there i will see if I can round up a link (I know i have it bookmarked somewhere) that tells how to test for "parasitic drain" that will discharge your battery. With these newer electronic marvels there is a special procedure for this.
Old Jun 21, 2004 | 02:21 PM
85e150's Avatar
85e150
You may consider replacing your idler on the serpentine belt. Mine spit itself off at 70K. Potential for cats-***-tropy if it flys off at speed. (radiator, fan, hood, front cover, battery, imagine the chaos of that thing hitting the fan if you loose it at 6000rpm)
norlandh
1997 - 2003 F150
Aug 27, 2010 05:56 PM
96_4wdr
Aerostar
Oct 11, 2009 02:20 PM
captainl67
Apr 20, 2008 08:49 PM
dgalloway
Jan 5, 2005 08:27 PM
knorton
Electrical Systems/Wiring
20
May 1, 2004 11:14 PM
