1999 explorer not charging.
Old Apr 20, 2008 | 01:16 PM
captainl67's Avatar
captainl67
Exclamation 1999 explorer not charging.
we have tested the alternator checked all fuses all wires, still will not charge the system. any ideas cause every thing shows its good. but no amps.
Old Apr 20, 2008 | 03:10 PM
87 XLT's Avatar
87 XLT
Dont know about your 99, but on my 97 theres a fuse between the starter relay & the voltage regulator. If it's blown it wont charge.
On a 97, it's mini fuse 6, under the hood in the power disribution box.
Is this one of the fuses that you checked?
You can probably find the charging circuit wiring diagram for your 1999 at autozone.com
Old Apr 20, 2008 | 08:49 PM
99f350sd's Avatar
99f350sd
30 amp mini fuse and a 175 amp mega fuse both have to be good. Make sure on the large wire you have battery 12v battery voltage if not the 175 may be bad.
Dick
Olds69442
6.7L Power Stroke Diesel
Dec 23, 2012 06:17 PM
rollerstud98
6.4L Power Stroke Diesel
May 11, 2010 09:15 PM
alangill.1
New Member Introductions
Mar 14, 2008 06:53 PM
yota69
Oct 13, 2007 12:08 PM
walkinez
Sep 15, 2004 09:19 AM
