92 Won't go into 4WD problem...
Old Dec 5, 2002 | 03:19 PM
marragtop's Avatar
marragtop
I have a 92 XLT 4x4 AT 4.0, 143K miles. It has the '4wd' and 'low range' push buttons on the dash. When I push the 4wd button, the lights on the button and instrument cluster come on, but I don't think it's engaging. When I try and put it in low range, nothing (no lights) come on. All the 4wd stuff worked last winter. Any/all ideas on what the problem could be would be greatly appreciated.
Also, does anyone know of a knowledgeable repair shop in the Balt Md area that is good with 4wd problems??
thanks in advance..
Mike
Old Dec 5, 2002 | 03:43 PM
mrshorty's Avatar
mrshorty
check that the transfer case motor is engaging the transfer case. check out http://www.glue.umd.edu/~singletn/exp.html for ideas. very common for the shift motor to get dirty and need cleaning.
Old Dec 9, 2002 | 09:42 AM
77redf250's Avatar
77redf250
first make sure the transfer case is working this can be done by placing the vehicle on jackstands putting it in 4-wheel drive and watching the front drive shaft to make sure it turns. if the driveshaft is turning but the wheels aren't turning the problem is in the hubs. If the 4-wd actually works with the wheels off the ground make sure all the tires are the same size.
Old Dec 27, 2002 | 09:39 PM
snuffy348's Avatar
snuffy348
I have a 92 explorer eb & also have 4x4 problems, but to get mine into low I have to be in neutral. Hope yours is working.
Old Dec 27, 2002 | 10:32 PM
labafile's Avatar
labafile
gcorse
Mar 26, 2014 01:26 PM
codyingersoll123
Jun 7, 2008 11:10 AM
gevalt65
Bronco II
May 1, 2006 08:04 PM
rgabriel
1978 - 1996 Big Bronco
May 3, 2002 12:08 PM
