<cr>
The eraser-sized spot (assuming it isn't a chip in the paint) is probably the size of a dime. You just can't see the problem yet.
There is no quick, invisible fix. In other words, no magic wand. Sanding until you have clean metal and properly matching the paint is the only way to eliminate the rust problem.
