Oil & Lubrication
shell rotella
Old Jun 14, 2004 | 07:56 PM
ford390gashog's Avatar
ford390gashog
shell rotella
how good is shell rotella t 15w 40 all the info i have heard is good
Old Jun 14, 2004 | 07:58 PM
rusty70f100's Avatar
rusty70f100
Good stuff. Haven't personally used it, but I see it everywhere, and it's diesel rated so it's good stuff. What are you using it in?
Old Jun 14, 2004 | 08:16 PM
ford390gashog
i think i was going to use it in my 75 ford truck with a 390 and my 2003 expy every one that used it said there car has lasted a long time a lot longer than it should my friend has been using it since 92 in his trans am which was a 1990 model he bought used at 30,000 it now has 460,000 and he plans on getting 500 plus has never had any engine problems just belts and alternator replaced and it still runs great we have been sending in oil to blackstone for their input and the results come back great no bearing material or anything else
Old Jun 14, 2004 | 09:02 PM
johnsdiesel's Avatar
johnsdiesel
I have used it almost exclusively since I bought my PSD. It's a good oil and is one of the most popular diesel oils on the market.
Old Jun 14, 2004 | 09:16 PM
peppy's Avatar
peppy
The other option is Chevrons Delo 400. I use RotellaT in my truck.....gas 302. RotellaT is a very good group I base. Delo is a group II base stock. As I learn more and more here.....I ask myself why I dont use the Delo 400 instead of the RotellaT.
I even asked Shell in an e-mail whyI should stick with them instead of switching to the Delo. Been over a month I think....no response yet.
Old Jun 14, 2004 | 09:31 PM
78fordman's Avatar
78fordman
rotella is a good oil, so is delo, delco, and jt-8. I switched to jt-8 and it runs just as good as rotella.
Old Jun 14, 2004 | 10:04 PM
rusty70f100
Yep the other, other option is Mystik JT-8. That's what I run. Works great. $0.95 / quart on sale, with the diesel ratings, I cant complain!
Old Jun 14, 2004 | 10:44 PM
TallPaul's Avatar
TallPaul
I have heard that Mobil Delvac is very good too. Just saw that my local Meijers store carrys the Delvac 15w40 in 2.5 gallon jugs for $15.99.
Old Jun 14, 2004 | 10:57 PM
bigrigfixer's Avatar
bigrigfixer
The Pacifier
When I do LOF's at work, some truckers specify Rotella T, others specify Delo 400. Others specify Shurcraft.
From what I understand, the difference between Rotella T and Delo 400 is the additive content. Delo 400 has more detergent in it, so you're getting "less" oil for lubrication. Rotella T, has less detergent than Delo 400, and stands to reason that there is more room for "more" oil to lubricate with. Either way you look at it, you could have "more" oil to keep yourself lubricated, or "less" oil that keeps the inside of your engine clean.
They are both excellent products. One thing I have noticed though, when it comes to changing the oil, the rig with Delo coming out has dirtier oil than Rotella coming out. That's a good thing. While Rotella still comes out black, I have to add this. If the oil coming out still looks clean, (ie: fresh out of the bottle) the oil isn't doing it's job, and it's time to start looking for a different oil.
Old Jun 15, 2004 | 06:37 AM
Icicle's Avatar
Icicle
what about delvac (mobil)?
Old Jun 15, 2004 | 07:50 AM
jim41's Avatar
jim41
Cant go wrong with Castrol RX Super Heavy Duty Multi Grade 15w40 You will never know,Unless you give it a go.We run it Cars ,Trucks,Tractors its the only oil we use in the workshop.
Old Jun 15, 2004 | 12:09 PM
jimandmandy's Avatar
jimandmandy
The last time I checked the spec sheets, Delvac 1300 had the highest TBN (and ash content) of the three major brands (Delo 400, Delvac 1300 and Rotella T). So, the additive pack is even higher than that of Delo. ExxonMobil still makes a lot of Group I base oil, so that is probably what is in it.
Jim
Old Jun 15, 2004 | 05:24 PM
Icicle's Avatar
Icicle
So switching to DELO in my high miles diesel is probably a good idea? Ive been running mobil delvac
Old Jun 15, 2004 | 10:11 PM
robduval's Avatar
robduval
when i worked for the local paving out fit we had a lot of one tons with 500,000 miles on them. most with the original motors. all they ran for oil in them was rotella
Old Jun 17, 2004 | 10:50 AM
Texan1983's Avatar
Texan1983
i run rotella T 15-40 in my 77 f150 4x4 with a 400 and love it.
