How to replace C6 shift lever
Old Jun 12, 2004 | 02:34 PM
starboy's Avatar
starboy
I hope I don't have to pull the pan, but that's not bad. What about the linkage assembly that's on that shaft, outside of the shift lever, can I safely remove that assembly?
Old Jun 12, 2004 | 03:47 PM
mark a.'s Avatar
mark a.
You have to romove the valve body too. only the bolts with 3/8 hex. Then remove the passing gear lever so you can get a 7/8 box wrench over it inside the case, to remove the shifter nut. Make sure you get the valve body shifter aligned with the manual linkage in the case. It's not hard to do.
Old Jun 12, 2004 | 04:11 PM
starboy's Avatar
starboy
So, I drop the pan, remove the valve body, remove the kickdown lever, change the shift levers and bolt everything back?
Old Jun 12, 2004 | 04:33 PM
mark a.'s Avatar
mark a.
Old Jun 12, 2004 | 08:48 PM
starboy's Avatar
starboy
that is very cool. Thanks.
jeff Heidel
Sep 1, 2015 04:56 PM
centralNH
Jun 1, 2014 05:41 PM
Steve Aerostar
Aerostar
Dec 6, 2013 10:10 PM
jerwiltho
Nov 27, 2013 11:44 AM
