Sponsored by: Real Truck
steering column problem
Old Aug 31, 2015 | 03:05 PM
jeff Heidel's Avatar
jeff Heidel
I have a 2002 F250 diesel, the key will turn to acc. but not on. It feels like it is hitting somthing in the column. I tried moving the shifting lever back and forth with my foot on the break, as I turned the key but it would not turn. I am thinking the tumblers are OK because it goes into acc. It feels like their is some lever that is not releasing the shift lever, because if I turn the key hard the shift lever jumps. Any ideas what is wrong, or how the interface between the lock tumbler and the shift lever works?
Old Aug 31, 2015 | 03:40 PM
Squisher's Avatar
Squisher
You mention wiggling the shift lever but obviously you've tried wiggling the steering wheel as well while trying to turn the key?
Old Sep 1, 2015 | 11:16 AM
jeff Heidel
Yes, I have wiggled the steering wheel. The steering wheel is not locked. Just the shifter is locked in park, and I cannot turn the key except to accessory and off. I have manually moved the shifter lock solenoid but the shifter still will not move.
Old Sep 1, 2015 | 12:53 PM
Squisher's Avatar
Squisher
I wasn't trying to be a smartass but had to ask.
Hopefully bumping this will get you some real help, I've never experienced the issue myself.
Old Sep 1, 2015 | 04:56 PM
seville009's Avatar
seville009
https://www.ford-trucks.com/forums/1...-ignition.html
fc111
May 27, 2019 02:48 PM
brockathin
Jul 10, 2016 11:19 AM
Mad.Scientist
Aug 26, 2009 12:27 PM
flyball
18
Apr 11, 2006 07:32 PM
the lorax
Oct 4, 2005 08:49 PM
