Engine/Electrical problems
Old Jun 11, 2004 | 12:06 AM
Broken Ford's Avatar
Broken Ford
Unhappy Engine/Electrical problems
I have a 1993 F-150 351 5.8L V8 EFI and i am having problems. When ever I start driving, and it starts to warm up the engine starts to miss out. Causing jerking. I went through and replace the plugs, wires, rotor, and distrubutor cap, but the problem is still there. What could the problem be???
Old Jun 11, 2004 | 06:18 AM
Bob Ayers's Avatar
Bob Ayers
How long has it been since the fuel filter was replaced????
Old Jun 11, 2004 | 10:00 AM
beartracks's Avatar
beartracks
There are several sensors that might be the culprit. They don't take effect untill the engines warms up enough to get out of closed loop. Oxygen, Intake air temp, water temp maybe even the knock sensor.
Old Jun 11, 2004 | 10:10 AM
Bob Ayers's Avatar
Bob Ayers
You have that backwards, with EFI, the engine runs in "open loop" until warm, then it runs in "closed loop".
Old Jun 11, 2004 | 03:30 PM
Franklin2's Avatar
Franklin2
If you think it could be a failed sensor, you could read the codes from the computer.
And if it will idle ok, but start to miss when you push the gas pedal, I would also agree with looking at the fuel filter.
Nmsandman
Jan 30, 2014 01:44 PM
huntsmuleys
1978 - 1996 Big Bronco
13
Dec 2, 2010 01:13 PM
kmule
Sep 4, 2009 01:42 PM
dwrestle
Sep 3, 2006 07:38 PM
bronco5.8
25
Sep 22, 2004 03:35 PM
