Mine seems to use a quart every 1,800 miles or so. What's your's use? Just check the closest option. If you get 3,000 or more miles with out using oil, post your answer in a reply.
I have a '99 v-10 with 33,000 miles. Twice I used about a half quart between changes. Since switching to synthetic, I don't use any.
Wow, I never use any between dino oil changes at 3,000 miles, but use 1/2 a quart or so with Mobil 1 synth but I change that at 5,000 miles, maybe that's the diff. I have heard Mobil 1 has a higher evaporative rate than most dino oils, and most synthetic oils. Amsoil advertises a lower evaporative rate than other synths, so I'm going to try that next change. Ken
'01 with 108k always use dino oil, no appreciable useage between changes.
3,000 to 3,250 miles between changes since I got it at 72k.
Did switch to Motorcraft filters this last change. (Yesterday actually) because of the rumor they will lessen the start up noise. No opinion yet, other than they are cheaper (For me) than the NAPA premium I was using..
just did mine 11 June 2004 on it's 1ST oil change at 3727 miler. Oil was clean,and it was on the full mark,with lots of 4x4 off road to see what this thing had.It did well except as all gas is tough..
I have the V10 in My Tioga Motor Home. It has used a quart of oil every 1500 miles since new. It has 28000 miles now on it no change. Still a quart 1500 miles. I have heard the earlier V10's were oil burners. One would think in these modern times Ford could do better that that! I can handle the oil issue it is blowing spark plug issue that scares me to death with the V10. Have three freinds that have had them blow out. 2 99's and one 2000. All farm trucks. BTW they use oild too, two of the use a quart in 2000 miless the 2000 model about the same. I have always used what the Ford Owners Manual states 5W-30
2001 4X4 Excursion. 66,700mi. I use Mobile 1 and a Motorcraft Filter. I change my oil anywhere between 4,000 and 5,000mi. Haven't used or lost a noticeable drop ever. Okay, maybe a little on the floor when I miss the drain pan.
