Cutting tool
Old Jun 10, 2004 | 08:38 AM
daveengelson's Avatar
daveengelson
Cutting tool
Can anyone give me some information on what they have found works best for cutting sheet metal. Want to replace floor pan, and panels. Understand tig is one of better methods of cutting sheet metal but not in my budget at this time. Have a disc sander, but from my limited experience, not sure can make the cuts that precice. I have an air compressor with 6-7 cfm capacity.
Any suggestions would be appreciated,
Thanks,
dave
Old Jun 10, 2004 | 08:53 AM
Huntsman's Avatar
Huntsman
I use one like in this link, they work great on sheetmetal and you can use them to cut circles with no problem.
http://www.harborfreight.com/cpi/cta...itemnumber=113
Old Jun 10, 2004 | 09:44 AM
daveengelson
Think meant to say 'plasma cutter' and not tig, what do i know. Thank you Huntsman for the info.
Old Jun 10, 2004 | 01:55 PM
Aekisu's Avatar
Aekisu
<cr>
A die grinder w/cutting disk works for me
http://www.harborfreight.com/cpi/cta...emnumber=36572
http://www.harborfreight.com/cpi/cta...temnumber=1103
Old Jun 10, 2004 | 04:12 PM
daveengelson
Will add the tool to my list. Ordered catalog from Auto Body supplier to compare prices, and quality.
Thank you for the info.
dave
Old Jun 10, 2004 | 06:13 PM
Greg 79 f150's Avatar
Greg 79 f150
I use a Dewalt 4 inch electric angle grinder at work to cut all my small guage metal, using the 1/8 inch x 4 inch metal cutting discs that I buy at Lowes. Those little guys will cut thru 1/4 inch plate steel fair, 1/8 inch good, 1/16 inch is history, plus they can be used to dress up the metal nicely too ,after leaving burrs.
Old Jun 10, 2004 | 08:51 PM
daveengelson
Thanx for the input. I have a Milwaukee electric angle grinder that takes the 4 1/2 to 5" disc. I find it difficult working with in tight places, and there are times when that little bugger gets away from me and so much for the straight line. Have alot of scrap metal that can practice on before i attempt cutting out floor pan. Probably looking to purchase 2 or 3 cutting tools so can have some options. Aint so good at welding and can only fill so much of a gap.
thanx again,
dave
Old Jun 10, 2004 | 09:30 PM
j wright's Avatar
j wright
Just food for thought, make a cardboard template first the transfer it to the sheet metal, and cut away with anything that works for you. you could leave an 1/8" and use a file to cut and smooth the edges. Like I said just food for thought.
John
Old Jun 11, 2004 | 02:25 AM
daveengelson
Really appreciate the suggestion. Did not think of using a template for the floor pans. Recently used template installing fenders on bed and found it extremely helpful.
Thanx,
dave
Old Jun 11, 2004 | 10:20 AM
Huntsman's Avatar
Huntsman
I have a side grinder and use it for grinding, etc and for cutting heavy gauge flat stock but the beauty of the body saw I mentioned, is that the blade is so thin and the cut so precise that the removed section of sheet metal can be used as a pattern to cut a replacement from and the fit will be perfect for butt welding that panel back in.
Old Jun 11, 2004 | 11:58 AM
SangRun Hunter's Avatar
SangRun Hunter
I have an air nibler and have found nothing that works quicker and cleaner for cutting sheetmetal. It does leave thousands of little 1/4 inch half moon shapped pieces of steel behind. Invest in a strong magnet to pick up the peices from your work area! They get in your feet really easy if you walk through barefoot later.
An air cutoff wheel is my next choice for sheetmetal.
Old Jun 11, 2004 | 05:45 PM
daveengelson
Just received my auto body tools and supplies catalog and started compiling a wish list. They have an air nibbler, and body saw by Ingersol-rand and from their description appear fairly good. Intend to get the die grinder regardless, broke mine couple years ago and miss it. Have couple other tool catalogs and will compare manufacturer and prices before making selection. Thanks for the info.
dave
Old Jun 14, 2004 | 04:40 PM
Rosati's Avatar
Rosati
Aww, come on guys, you don't need all of that fancy equipment to cut sheetmetal.
Peersonally, I started out using a reciprocating saw (sawzall, etc) with fine toothed blades. Pretty easy for roughing out the opening.
Then I used a jigsaw/scrollsaw. Makes for getting in some tighter areas.
ThenI bought a die grinder and some cutoff wheels. Unless you have 10+ cfm from your compressor, be ready to wait awaile between short cuts.
Now, I use my sawzall and a 4 in grinder with large cuoff wheels. I rough out the piece then use the grinder and or a belt sander to smooth up the edges.
If I'm just cutting a small piece to patch a small hole or trim a panel, I use my aviation snips.
Plasma cutters are great for repeat or producton work but offer no real advantage to the home user. (unless you are cutting a truckload of structural steel.)
jrockdiddy
34
Apr 11, 2015 10:25 AM
KC Ray
Aug 28, 2012 08:06 PM
Coneynew
Paint & Bodywork
Dec 8, 2006 06:36 PM
Pudmullet
19
Oct 20, 2006 10:27 PM
bronocIInoob
Paint & Bodywork
Mar 1, 2006 08:18 PM
