'51 COE sheet metal
Old Oct 19, 2006 | 07:00 AM
Pudmullet's Avatar
Pudmullet
'51 COE sheet metal
What are the options for sheet metal repair on a '51 COE? There are a couple rust spots that I hope can be patched. Is there replacement sheet metal? It doesn't look like anything is the same as my '48 F6.
Old Oct 19, 2006 | 07:46 AM
bobj49f2's Avatar
bobj49f2
I don't know of any mass produced reproduction parts for a COE, there aren't many for conventional cabs. I think Reamer, from this board, has made patch panels for the cab corners that will work on COEs. Check with him. I personall make my own metal patches for my trucks, I'm cheap and I also like making them.
Old Oct 19, 2006 | 10:29 AM
Minger's Avatar
Minger
Do you have an English wheel or you just hammer and dolly away? Any easy tips for a beginner body repair man? How do you make a template?
Old Oct 19, 2006 | 11:00 AM
bobj49f2's Avatar
bobj49f2
If it's a difficult panel I use a piece of thin cardboard to make a template. If the patch goes around a curve or corner I cut slits following the conture and bend the "fingers" over and weld the slits shut. I don't have an English wheel, I use basis body hand tools and and MIG welder.
I had to reconstruct the inside of the the corners also but like I said, I like doing metal patches.
Old Oct 19, 2006 | 11:05 AM
Minger's Avatar
Minger
Wow, you are killing me here. I am supposed to be finsihing up two homework assignments due today but here I am admriing you work. Nice stuff. If I may ask another question, where do you buy your sheet metal and what gauage and composition of steel is it? I'm a newbie at this. Cool pics though and nice work
Old Oct 19, 2006 | 11:11 AM
bobj49f2's Avatar
bobj49f2
I use whatever I have around. I wouidn't use anything thinner than 22 ga. I use the thickest metal I can work with. I run a control panel shop and work with a lot of 14ga metal which is fairly thick and I have a lot of scrap from cutting holes out of the control panels. I have also bought metal from any place that sells body shop supplies and places that sell sheet metal to the industrial market.
BTW, I should be working too instead of playing around on the computer
Old Oct 19, 2006 | 11:44 AM
51PanelMan's Avatar
51PanelMan
The COE fenders and grille are different than F1 and F2-F6 trucks. COE's share front end parts with F7-F8 trucks. So, if you're looking for replacements or patch panels, you need to find yourself fenders from a 51/52 F7 or F8. You might be able to use fenders (for patching) from a 48-50 F7, F8 or even a COE depending on what you need to patch on yours.
I wish I had a 51 or 52 COE. A COE and a fire truck are my Bonus Built trucks holy grail.
Ilya
Old Oct 19, 2006 | 01:35 PM
AXracer's Avatar
AXracer
For bodywork you want 18-20ga cold rolled sheet steel. It should be silver in color rather than black (indicates hot rolled, a cheaper harder to work steel. It can be used for simple repairs, but the black surface needs to be sanded off before welding or painting) The best metal is called Aluminum Killed Steel or Deep Drawing Steel, it is soft and easily worked, but it is hard to find. Avoid galvanized or coated steels. If you haunt the local sheetmetal fabricators shops (I usually look for a back door or loading door directly into the shop rather going thru the office door and talk to one of the guy working inside) that work with these type metals and ask if you might scrounge thru their "drops" (cutoffs too small to be of use to them) pile for useable to you pieces. They will often give them to you or charge a small amount for them. If they give them to you and/or are especially friendly, I'd bring them back a box of donuts the next visit!
Carry a wire gauge or cheap micrometer with you to check thicknesses.
I've mentioned it many times in the past, but an excellent source of info for the novice bodyman is Ron Covell's video: Basic Techniques for Working with Steel. www.covell.biz
Much better to SEE the work being done. Don't try to cut corners when repairs are needed, remove and replace any rust out, including any underlying structure.
Do a search for my posts, I have posted a lot of info on doing bodywork in various topics.
Old Oct 19, 2006 | 06:12 PM
tomoto's Avatar
tomoto
looks like a nice .I wish my was a barn find,I have 3 coe ,only 1 I can drive
Old Oct 20, 2006 | 07:23 AM
reamer's Avatar
reamer
COE cab corners are the same as F-series trucks. I made dies for these and press them out.
Old Oct 20, 2006 | 10:48 AM
Pudmullet's Avatar
Pudmullet
Wink
Thanks guys for all the help. I'm learning allot about these trucks. Looks like whenever I get them home and can get started, I'll have to do some cutting and welding. It's great to know that reamer is making the patches I'm going to need. I have most of the equipment I think I'll need to do most of the work, but I'm a rookie. I have a large compressor, pressure pot blaster, blast cabinet, mig welder, torch set up, 20T press, engine hoist, fork lift, etc. I'll have to get a gas set up for the welder and get some practice work in. I'll also probably need to get some painting equipment so I can at least prime what I blast. Oh well, first things first. I need to get 'em home. Thanks again!
Old Oct 20, 2006 | 11:09 AM
AXracer's Avatar
AXracer
definitely want shielding gas for the mig for sheetmetal. A 4" or 4 1/2" angle grinder with a quantity of cutoff wheels for trimming, some 60 grit flap wheels for knocking down the welds, a pickhammer with a round face other end plus a universal and/or toe dolly for stretching weld shrinkage and shrinking any stretched areas. A small tip for your torch for shrinking. 6" pneumatic DA sander, right angle die grinder, a decent gravity feed HVLP spraygun with tip for epoxy primer.
That should get you started, do we ever have enough tools?
Old Oct 20, 2006 | 12:07 PM
51PanelMan's Avatar
51PanelMan
Nice trucks! However, your COE is not a 51. It's a 48-50. Same as the other truck.
Ilya
Old Oct 20, 2006 | 01:20 PM
bobj49f2's Avatar
bobj49f2
Ilya, Ilya,
I am surprised at you. The COE is a '51 but has a '48-50 hood. I blew the image of the front fender to offer as evidence:
Note 1: One of horns of the grill is sticking out
Note 2: The head light on the '51-52 protrude further out than the '48-50
Note 3: The bottom line of the fender, '48-50 don't have this ridge.
I rest my case
Would you believe my wife thinks I'm obsessive about these old trucks?
One more tool that comes in extremely handy, especially for big, straight panels , is a in-line air file. It will really helps when it comes to doors and the big, wide fenders on the Bonus Built trucks.
Make sure you get a dual cylinder unit.
Old Oct 20, 2006 | 03:10 PM
Pudmullet's Avatar
Pudmullet
Ilya
It must be a '50 then, because the grill is different than the '48. I think I read somewhere that Ford changed the the grill in mid '51.?????? I haven't picked up the titles yet so I don't know what they have on it. Guess I'll find out when I can dig into 'em.
