Sheet metal cutting tools
Old Jul 7, 2013 | 03:50 PM
jrockdiddy's Avatar
jrockdiddy
What tool do you guys prefer to cut thin sheet metal for patch panels? Example cutting a curve or something...
Question #2
What do you guys use to cut straight lines on thicker gauge metal?
Old Jul 7, 2013 | 05:06 PM
bobj49f2's Avatar
bobj49f2
I've been spending the last 4-5 days making patch panels for my '37 Buick. I course cut with a plasma cutter and then clean up with flapper type grinding disc.
I really should be using tin snips for the parts but I don't have a good set and just never think about buying one when I'm at the store.
I also use a saber saw, it all depends what I think works best for the job at hand. For heavy metal the plasma cutter works great but I also use a horizontal band saw for flat stock, angle iron and pipe. I use torch for other things.
You all should check out this video, it's extremely informative on how to use tin snips and what kind to use.
<iframe width="420" height="315" src="//www.youtube.com/embed/qAOQfUaRZyw" frameborder="0" allowfullscreen></iframe>
Old Jul 7, 2013 | 06:43 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
I have been using tin snips wrong all long. Always upside down. And I never understood why I was always curling the wrong piece or ofen trying to go right through the middle of the piece.
This was a great video. Thanks for sharing.
I can't give you more reps until I spread 'em around... again.
Old Jul 7, 2013 | 07:07 PM
TireDood's Avatar
TireDood
I always use an electric or pneumatic angle grinder with a cut-off wheel, mostly because that is what I have to use. I've never had much luck with snips, I always seem to bend everything all out of shape. I would like to have some pneumatic nibblers, just haven't bought them yet. Measure twice, cut once, and then spend some time with a flap disc getting it just right....
Old Jul 7, 2013 | 07:49 PM
bobj49f2's Avatar
bobj49f2
Are you typing about the nibblers that chomp little half moon shapes out of the sheet metal as you go along? If you are I highly recommend not get one. I worked in a body shop that had one, those damned little moons were all over and like to embed in the bottom of you shoes so you can take them home with you. I had an electric shears and it worked pretty good but I think the blade got dull and worked like crap.
I would still with the shears over the nibbler.
Old Jul 7, 2013 | 07:51 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Same here... I just never really thought about it! There is a similar video on files that was equally enlightening.
Old Jul 7, 2013 | 08:08 PM
CharlieLed's Avatar
CharlieLed
Nice video, thanks for sharing. I watched my Dad use snips on and off for years and thought that I knew pretty much all there was to know about their use...I learned that I didn't know as much as I thought.
Old Jul 7, 2013 | 08:24 PM
ChuckRob's Avatar
ChuckRob
i got an electric metal cutting shear from Eastwood, it really works great for straight cuts and large radius cuts.
18 Gauge Electric Sheet Metal Shears | Electric Metal-Cutting Shears
Old Jul 7, 2013 | 09:23 PM
Chris 56 f6's Avatar
Chris 56 f6
Thanks for posting that video ! I started using tin snips with my dad at the age of 14 . He was a aluminum sider and I worked with him every summer and after school till I was out of school . I now use tin snips almost every day depending on what I am building that day. That video told me a lot that I did already know but also told me a new/ better way to cut. Thanks again
Old Jul 7, 2013 | 09:41 PM
Chris 56 f6
I cut all kinds of metal from aluminum to stainless steel to tin ... I have several tools to do this . I like to use electrice shears for thin steel/tin and electric nibblers also for steel
If I am cutting thicker gage steel I use a metal saw like this one
This saw can cut 2" cold steel bar . I can cut 1/2" plate steel with it too !
Old Jul 7, 2013 | 09:48 PM
Chris 56 f6
Here's a video of the saw in action
Old Jul 7, 2013 | 10:27 PM
fixnair's Avatar
fixnair
No wonder I could never get those to work for me! I've been doing it wrong and trying to get a cheap pair to perform. Thanks for the video.
Old Jul 8, 2013 | 01:51 AM
underthebridgejim's Avatar
underthebridgejim
FTE fan
Amazing, now I know why my snips never worked worth a hoot, PILOT ERRORRRRRRRR! LOL
Old Jul 8, 2013 | 07:43 AM
oldmerc's Avatar
oldmerc
oldmerc
Most of the time I use a Beverly Shear or a Straight Shear . I use my nibbler for detailed cuts out of the inside of a panel or a pair of Pneumatic Shears for braking down large sheets . Then I'll use snips for trimming .
Old Jul 8, 2013 | 12:15 PM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
So I'm the only guy on the planet that uses a pneumatic body saw?
Am I missing something?
