Over drive trans
Old Jun 10, 2004 | 01:38 AM
beaver77's Avatar
beaver77
Over drive trans
I am restoring a 77 f150 4 wheel drive. It has a 400 engine, I would like to use a manuel overdrive trans. I am looking for suggestions on what transmission would work best.
Old Jun 10, 2004 | 04:38 AM
whd507's Avatar
whd507
clark 5-sp from an F-500-800
Old Jun 10, 2004 | 08:26 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
Would a five speed from a newer f 250 / f 350 that had a 460 work?
Old Jun 10, 2004 | 01:29 PM
rjlougee's Avatar
rjlougee
A ZF5 from an '88-97 F250-450 series with the diesel or 460 would work, or even one of the ZF6 trannies from the Superduties. However, the ZF6 ratios from the diesels aren't really friendly for a gas engine. (gas is 5.72-.076 diesels are 4.14-0.70 for the ZF5, similar with the ZF6, but 6 gears and about 6" longer overall)
In addition to the tranny, you'll have to deal with it having an integral bellhousing, plumbing a hydraulic master cylinder in and it being a PIA to replace the slave cylinder.
In the long run it's VERY worth it. I have the ZF5 in my '75 Bronco and am looking to install one in the '77 crew cab F250 I'm building as the tow rig (also adding a diesel, etc...).
Old Jun 10, 2004 | 01:54 PM
whd507's Avatar
whd507
I have a zf-5 in my powerstroke, and if I could, I would replace it with almost anything else. its garbage. E40D is a big step up from that piece...
Old Jun 10, 2004 | 02:04 PM
whd507's Avatar
whd507
my 500+ thousand mile clark sounds like its processing rocks into sand, but it shifts much better and smoother than the 170,000 mile ZF abomination in the diesel... the zf needs to be double-clutched into every gear except OD
Old Jun 10, 2004 | 04:04 PM
rjlougee's Avatar
rjlougee
What transfer case mounts up to the back of the Clark?
Old Jun 11, 2004 | 12:17 AM
whd507's Avatar
whd507
I imagine you would have to use a divorced transfer case. there are some guys who have made custom adaptors, and the clark is a popular trans with serious jeep people, so there may be an adaptor available that I do not know about.
a clark with O/D has both granny low (you can start in third) and 5th is an OD gear.
Old Jun 22, 2004 | 10:38 PM
cowboy_79_1999's Avatar
cowboy_79_1999
NV4500 is the way to go. advance adapters has everything you need to bolt it in, and your stock clutch linkage works with it. Most major change is changing the tranny mount, moving the t-case back, shortening the back, and lengthening the front drive shaft.
77 F-150 lwb stepsid
17
May 2, 2014 11:57 PM
old blue beast
Jul 9, 2013 06:49 PM
don77
Jan 2, 2009 05:11 PM
77fordcrewcab
Dec 18, 2006 11:08 PM
padd77
Aug 19, 2002 11:57 PM
