Aligning/Adjusting Headlight Beams
Old Jun 8, 2004 | 09:34 PM
MemOrex's Avatar
MemOrex
Does anyone know how to adjust the beam position on a 93 f-150? One of my beam shoots lower than the other. any help?
Old Jun 8, 2004 | 11:33 PM
95soontobelifted's Avatar
95soontobelifted
there is an adjustment rod above the headlight with the hood open. It should be a very small little rod that you can fit a very small socket onto. If you turn it clockwise it should raise it, if not go the other way. It adjusts the entire headlight by moving the bottom in and out.
Old Jun 9, 2004 | 07:41 PM
MemOrex's Avatar
MemOrex
Thanks, 95, i got it.
Old Jun 9, 2004 | 09:03 PM
95soontobelifted
np. I picked that up after replacing the chrome window around the headlight.
Old Jun 10, 2004 | 08:35 AM
MemOrex's Avatar
MemOrex
Well, now my lights are fine, but my friend has different problem. One of his lighst points more to the side than the other. Any idea how to align them left/right?
Old Jun 10, 2004 | 07:05 PM
95soontobelifted
I beleive if you look between the chrome molding and headlight you will see a visible philips head screw on the upper right or upper left, tightening or loosening that screw should adjust the beam left to right.
Old Jun 10, 2004 | 07:26 PM
MemOrex's Avatar
MemOrex
Thanks for your feedback 95!
I_Thnk_Ford
General Automotive Discussion
21
Jun 8, 2015 11:07 PM
V10man
Aug 22, 2012 03:47 PM
llehmn
Oct 6, 2005 07:54 PM
Boltgunner
Jul 6, 2005 03:06 PM
JKP87
Apr 22, 2000 04:50 PM
