Sponsored by: Kumho
I-Beam Bender
Old Jul 5, 2005 | 09:47 PM
Boltgunner's Avatar
Boltgunner
I-Beam Bender
Anyone have info on a tool I have only heard about that is used to bend the front I beams to adjust camber? Also, is there a printed procedure for the proper use of this tool?
Old Jul 6, 2005 | 03:06 PM
god.boots's Avatar
god.boots
i wanted to do the same thing, i called up alot of my local shops, and they said they can only bend them 1-2 degrees, i needed a bigger bend than that because I lifted my front 4". If you dont have a big camber problem then you can use shims, if you have a big one you can buy some drop brackets for the i-beams.
I_Thnk_Ford
General Automotive Discussion
21
Jun 8, 2015 11:07 PM
Torky2
1978 - 1996 Big Bronco
Jul 30, 2011 06:27 PM
65fordguy
Oct 20, 2007 04:36 PM
llehmn
Oct 6, 2005 07:54 PM
Randyb12
May 27, 2004 11:06 PM
