Need to know height to adjust 92 F150 headlamps
Agree with the machine. However rule of thumb - flat level ground park vehicle 3m from a wall. Wall needs to be marked with a corresponding centreline to that of the vehicle. Measure either side of the centreline to the centre of the headlights and transpose measement to wall now measure height from ground to centre of headlight subtract 25mm( 1") and transcribe to wall. Turn lights onto park and adjust. The problem with rule of thumb is that some states/countries have special requirements and therfore the machine is the best approach.
I adjust mine by finding an empty parking lot, and adjusting the low beams out as far as they'll go without losing their intensity. I try to find a lot with a long straight line I can use to simulate the center line on the road and adjust left to right until it hits the line I'm using as a guide. If the high beams are too high - oh well.
Trail Rider
Trail Rider
Skalywag
07-10-2014 12:11 AM
MemOrex
06-10-2004 07:26 PM
PA F150 4X4
06-02-2003 07:01 PM
