Hi All!! Thanks in advance for any help you can give me...Here are my troubles with my truck-
1. When running the AC, the truck dies when I come to a stop. It restarts just fine, but it is still annoying when your truck always dies on hot summer days!
2. Code #32 comes up on the code reader, what exactly do I need to replace, and what is the easiest way to erase the codes?
3. Check engine light flashes when driving up a slight grade(like a freeway on-ramp, or mountain roads) Is this a short somewhere, or is it flashing out a trouble code?
If you know what may be going on with my truck, I appreciate your reply!! THanks again!
By the way, the truck is an 88 F150 2WD 5.0 F/I Has about 200,000 miles on it...give or take a few...any suggestions as to what the problem may be...Thanks
