Cooked starter?
Old Jun 8, 2004 | 02:42 PM
78f3504x4's Avatar
78f3504x4
Cooked starter?
Last year my 71F1004x4 sometimes would't start, and since I have headers I believed it to be fried starter. Now I just get home and turn the key off, pull the key out, and the truck stays running. I just stalled it to shut it off. Is this another charateristic of a bad starter?
Old Jun 8, 2004 | 02:50 PM
Ratsmoker's Avatar
Ratsmoker
Does the truck stay running normally after you pull the key? If so you need a new ignition switch or you have some shorted wires somewhere. When you pull turn the key off it is supposed to kill power to the ignition coil.
Old Jun 8, 2004 | 03:51 PM
78f3504x4's Avatar
78f3504x4
No, actually it seems the problem started after a Pertronix install. Could this be the culprit? Not starting maybe every 10 tries. The truck stays running after the key is out.
Old Jun 8, 2004 | 04:36 PM
gtex's Avatar
gtex
sounds like the wiring isn't right and the coil is hot most of the time, draining the battery.
Old Jun 8, 2004 | 04:48 PM
Ratsmoker's Avatar
Ratsmoker
Do you hear the solenoid click when it doesn't start upon turning the key? Sounds like you need a new ignition switch.
Old Jun 8, 2004 | 09:16 PM
fordeverpower's Avatar
fordeverpower
I had a sable once that when you pulled the key it stayed running. Worked well in the winter. Could leave the car, lock the doors and come back to heat.
Old Jun 8, 2004 | 11:02 PM
Randyb12's Avatar
Randyb12
Sounds like you need to recheck the wiring on that new ignition. It is getting juice all the time. This would cause the battery to discharge causing the starting problem and would explain the key not shutting the engine off.
Old Jun 9, 2004 | 07:30 AM
78f3504x4's Avatar
78f3504x4
After I read all this, I'm leaning towards the ignition switch, probably not a very expensive part.
Old Jun 9, 2004 | 08:13 AM
gtex's Avatar
gtex
If the above is true, and you did not have a problem with the switch before the pertronix install, then I would suspect the wiring more than the switch.
Old Jun 9, 2004 | 05:03 PM
Randyb12's Avatar
Randyb12
I agree with Greg. I don't think it is the switch.
Old Jun 10, 2004 | 08:01 AM
78f3504x4's Avatar
78f3504x4
I'll check it out. Thanks guys
Alabama1988
18
Sep 5, 2014 06:06 PM
Phil Woolfson
Jul 9, 2014 08:15 AM
hornsurgeon
1997 - 2003 F150
Dec 3, 2012 07:34 AM
ManicMike
Nov 12, 2011 10:13 PM
Crucifixation
1997 - 2003 F150
Dec 27, 2004 02:02 PM
