manual locking hubs help
Old Jun 8, 2004 | 09:18 AM
red85f250's Avatar
red85f250
I have an 85 F250 and I am replacing the hubs on it.. on the drivers side I cant get the hub assmebly to go far enough in to get the axle lock ring on, but on the passenger side it goes on fine.. what will happen if there isnt an axle lock ring? or how can I fix this?
Old Jun 8, 2004 | 02:45 PM
TallGuy_Az's Avatar
TallGuy_Az
My '81 F150 should be similar to yours. There have been times that during a 4X4 trip, under extreme crawling situations, my snap ring has actually come off. What happens is that the axle backs out of the hub, allowing the axle to become disengaged. When it first happened, I thought I broke an axle or something, but luckily I figured it out.
Being a TTB front end, you can grab the axle shaft and force it outwards as hard as you can so that any slop is taken out. Then there should be just enough room to fit the ring back on.
Hopefully this works - worked for me.
Old Jun 8, 2004 | 04:37 PM
andym's Avatar
andym
Yeah, you don't want to run without that snap ring in place. I would do as recommended, but let me explain it a different way: push the axle shaft outboard by reaching around behind the knuckle and putting a screwdriver throught the u-joint. You should be able to push it out far enough to get the snap ring on. If that still doesn't work, try (lightly) tapping the hub into the housing with a hammer and a punch. A combination of the two should work.
If not, the splines either on the axle shaft or inside the hub may be damaged.
meb9796
Feb 20, 2012 02:38 PM
MattL09
Sep 9, 2009 09:40 PM
comertrucks
Apr 8, 2006 11:16 AM
yamahawg
Jul 3, 2004 04:26 PM
rollingthunder1
Jul 5, 2001 10:30 AM
