How much can you Bench???
Old Jun 14, 2004 | 01:41 PM
  #91
Viken's Avatar
Viken
the person or people who stand ready to get the bar if something goes wrong. with heavy weight alot can go wrong. when i go over 315 i have some one to help with the lift off and to make sure i can press the weight.
Old Jun 14, 2004 | 01:49 PM
  #92
Greg 79 f150's Avatar
Greg 79 f150
I remember watching those "spotter" guys on tv heavweight contests. I could see where if a 400 lb. weighted bar dropped back across the forehead or crushed the windpipe, it could be fatal.
Old Jun 14, 2004 | 01:55 PM
  #93
Viken's Avatar
Viken
i have seen people get hurt on 250 Lbs. any time you get close to your max and just don't have the juice get a spot.
  #94
rmilchman's Avatar
rmilchman
That would hurt.... Also a joke when saying, what's a spotter. I no longer workout in a gym, just more ocnvenient to do it home after putting the kids to sleep.
Old Jun 14, 2004 | 09:22 PM
  #95
speedwheeler's Avatar
speedwheeler
im 19 6'3" 280 pds i think i can lift 150 max but i did once lift a small block chevy only 3 inches off the ground to get a cart under it my back hurt the next day
Old Jun 14, 2004 | 09:44 PM
  #96
MW95F250's Avatar
MW95F250
I don't know, I've never tried bench pressing or anything like that.
I do know that I can pick up 2 John Deere Suitcase weights (120lbs. ea.) off the ground up to the weight bracket, and then slide them on the rail.
I'm 6'6", 260lbs., 18 years old.
Old Jun 14, 2004 | 11:11 PM
  #97
Budly's Avatar
Budly
Where can you get a Bench Shirt at and how much do they cost?
And how the hell can they give you a 100 lbs. advantage?
Old Jun 14, 2004 | 11:18 PM
  #98
There Goes The Neighborhood's Avatar
I have no upper body strength. I'm 6'6", 420 lbs., 17 years old. I can max 190 on the bench, curl 240, and leg press 760 lbs.(school gym was outta weights).
Old Jun 14, 2004 | 11:58 PM
  #99
Budly's Avatar
Budly
your curl isnt to horrible... you are friggin huge... 6'6 420 at 17? WOW! I thought i was big, 6'6 320 and i am 19.
Old Jun 15, 2004 | 12:04 AM
  #100
feddoc's Avatar
feddoc
I dunno about the 100lb advantage, but, the way they work is similar to compression shorts.
They, the shirt, allow the muscle(s) to expand against something which allows the muscle to utilize more of the force generated by the contraction for moving a joint instead of expansion.
Old Jun 15, 2004 | 12:18 AM
  #101
Budly's Avatar
Budly
[QUOTE=Viken] for you guys that don't know a bench shirt can give you over 100 lbs on the benchQUOTE]
I am guessing that means 100lbs advantage.
Old Jun 15, 2004 | 09:15 AM
  #102
Viken's Avatar
Viken
in some cases it will give you more than 100LBS. back in the mid 90's i was on the power team at Eagle gym in st. Louis Mo. Willie Wessels weighs 235 Lbs and still holds the squat record of 1009Lbs. his bench was over 700LBS. the shirt gave him hundreds of pounds. it only gives me 100lbs. it takes a few people to put it on, because it is so tight. when i have it on 300lbs will not even touch my chest. at about 335 or more it will go down to my chest. it really does protect your body. you must still have the control of the weight and the power to lift it.
Old Jun 15, 2004 | 09:48 AM
  #103
95-F-350-4x4's Avatar
95-F-350-4x4
Interesting! Never heard of these things before. Are they expensive?
Old Jun 15, 2004 | 12:59 PM
  #104
rob_nc's Avatar
rob_nc
See this link for one of the best names in Power Lifting.
http://www.inzernet.com/
Old Nov 18, 2007 | 12:19 AM
  #105
J Hodges's Avatar
J Hodges
I'm 17 weigh about 180 and 5'8 the best I can do is 150 on the bench. I want to get to 200 in about a year
