Head Removal Tips
Old Jun 23, 2004 | 04:07 PM
  #31
Wakeboarder141's Avatar
Wakeboarder141
I have a friend who is more experienced who was going to do it. I just need to find a welder. I'l check on prices and maybe rent one this weekend. Might be good time to get to work on the wakeboard tower for my boat while I have the welder
Old Jun 23, 2004 | 04:12 PM
  #32
Brettddglas's Avatar
Brettddglas
Exclamation
I use to do this kind of work all the time. We had a machine made for removing this called an EDM and it would burn out the old pieces. It is very accurate and usually would just chase the threads when you are done. Depending on where it is, sometimes can do it in the car. Cost when we did it were around $75.00 (if we could do it in the car or you brought the head in to us. Head and/or exhaust manifold R&R not included).
If you try welding the nut to the ezout make sure you disconnect your battery and computer before you do this or you may be looking at some major expenses you werent ready for!
And if you used a cheap ezout then I doubt you will be shattering it since most of them are just case hardened.
The other alternative is to carbide drill it out but that is tough (have done my share of that as well) and if you shatter that while drilling, which is easy to do, then you will HAVE to be EDMing it out.
Good luck and keep us posted.
Old Jun 23, 2004 | 07:13 PM
  #33
Wakeboarder141
Thanks for the tips. Disconnecting the battery is easy enough, but how do I disconnect the computer? Is that as simple as just disconnecting the wiring harness from what I understand to be the computer that is mounted on the drivers side under the hood? Thanks.
Old Jun 23, 2004 | 07:23 PM
  #34
TigerDan's Avatar
TigerDan
Good point on disconnecting the battery and computer, I had forgotten about that. The PCM (computer) on your Bronc should be inside the cab, behind the pass. side kick panel, but I can't swear to that as I'm not all that familier with your year/model, that's just where Ford seems to put them on just about all the other computer-controlled trucks I've worked on. -TD
Old Jun 23, 2004 | 08:41 PM
  #35
Brettddglas
yes, I think it is in the kick panel. You will need a 10mm socket to remove the center screw and then pull the plug out of the computer.
Old Jun 26, 2004 | 09:58 AM
  #36
bremen242's Avatar
bremen242
you could take a oxy-actelyne torch and burn the ez-out out of the bolt.. you'd have to be fairly careful when doing that though..
i've done the MIG trick.. it didn't work for me though.
Old Jun 26, 2004 | 02:16 PM
  #37
Wakeboarder141
Why did that not work for you? Is the weld not strong enough to turn the bolt?
Old Jun 26, 2004 | 10:24 PM
  #38
bremen242's Avatar
bremen242
no.. it broke..
Old Jun 26, 2004 | 10:45 PM
  #39
ga302p's Avatar
ga302p
I'm Good with an oxy-acetelyne torch, but I know I couldn't burn a bolt out of an exhaust manifold bolt hole without boogering something up.
gameover1974
Nov 27, 2015 11:05 PM
91Bronc300
22
Apr 6, 2009 08:16 PM
sbclemens
Feb 15, 2008 10:04 AM
farmerboy
Mar 31, 2006 07:17 PM
Goodsath
1978 - 1996 Big Bronco
Nov 13, 2002 06:22 PM
