The infamous floorboard popping & NOW knock whenever I'm on rough roads has been diagnosed as a bad right shock... which certainly satisfies all symptoms.
Instead of paying them 200$ to replace the two fronts, I figured I'd upgrade and do all 4. So... what should I get? I'd like Ranchos, but I'd like to prevent breaking the bank...
If you don't really need the adjustables, you can go with Rancho RSX as I did. It will save you a few bucks and I am happy with their performance thus far.
I just replaced my rear shocks with the Rancho RSX's. So far very pleased. I have a 4X2 and had a hard time finding good shocks for the front. Rancho has a part number for a RSX shock for the front, but no one carried it. I finally found a pair of Edelbrock shocks for the front and am pleased with them also. The install on both was pretty easy.
I went with the Edelbrock IAS shocks and they are amazing.
No body roll in the corners and rides smoother than the truck ever
did before, abosrbs bumps and responds fast
