mileage
Old May 30, 2004 | 09:03 PM
chrowen's Avatar
chrowen
mileage
How much do you think i would gain in fuel economy by switching from an edelbrock 600cfm (1406) to the 500 cfm (1403) carbs? Right now i get about 8 mpg on my FE 390.
Old May 30, 2004 | 09:18 PM
Ratsmoker's Avatar
Ratsmoker
Is this 8MPG in the city? Is this stock? What gears do you have? I get 12MPG on the highway with my 390 and 3.70 gears. I have a 770cfm carb.
You may need to change the jets. I doubt going to a 500cfm would change things much and might cost you some power. 600cfm is about perfect for a stock to mild 390.
Old May 30, 2004 | 09:26 PM
chrowen's Avatar
chrowen
4.10 gears (35" BF's)
crane truck cam with edelbrock heads and edelbrock rpm intake
MSD 6a with pro billet distr.
I was hoping to switch between carbs for driving and for play. Maybe i should try the .095 jets (.098 right now) and different metering rods? Do they make smaller jets for the 1406 carb from edelbrock?
Old May 30, 2004 | 11:26 PM
Ratsmoker's Avatar
Ratsmoker
I know nothing about the edel carbs but make sure that you have light advance springs. You could be running very retarded at cruising RPMs. This is where vacuum advance really works well. I got 12MPG without it though. Lean the primaries out until it starts to hesitate at part throttle and then go back up a couple sizes.
While the 35s take more power to push down the road your effective gearing is probably about the same as mine if not better for mileage.
Old May 30, 2004 | 11:28 PM
fordeverpower's Avatar
fordeverpower
I only got 8mpg with a 79 4x4 and a 600 edelbrock. Thats with 3.50 gears and 31s.
Old May 31, 2004 | 02:42 PM
rebocardo's Avatar
rebocardo
Have you recalibrated your speedomter or transmission drive gear? If the stock tire was a 31 and you put 35s on it, your speedo is turning much slower then normal.
I have a 2150 2 bbl, beat 390, 31s, and I think 3.54 gears and all I get is 8 mpg, maybe 10 on the highway - hard to tell exactly since I can not fill may tank all the way since it sprung a leak.
Old Jun 2, 2004 | 09:43 PM
chrowen's Avatar
chrowen
what jets and rods are you running in your 600 edlebrock?
Old Jun 2, 2004 | 09:47 PM
chrowen's Avatar
chrowen
sorry, what about the springs...5, 6, 7 mmHg (what is stock strength anyway). Which is better for a leaner cruising burn?
Old Jun 3, 2004 | 03:29 PM
Big Dave's Avatar
Big Dave
Talking 390 getting 14 MPG
I just drove my 75 F250 2WD to Sacramento CA from Salt Lake City UT and got 14 MPG at 70-75 MPH. I was running empty with the tail gate down. I have done everything I could think of to get better mileage without spending a fortune.
My engine is a rebuild with 45K mi, bored .030 over with an "RV" cam (don't know which one or the specs, my dad had it rebuilt about 10 years ago) NP 435 trans, 3.73 gears and 31" tall 235 85 16 rear tires. The engine is stock with the exception of the cam, Edel 1406 carb and Accel super coil with the plugs gapped at .055". The only other thing I did was I took the belt off of the smog pump (CA truck) and capped the vacumn line to it. I am very pleased with the power and the mileage as it is used mostly for hauling my camper and play toys behind it.
The truck gets a little better mileage now than when it was new. My dad says that it used to get about 12 MPG when new in stock form.
Old Jun 3, 2004 | 09:24 PM
fordeverpower
I ran the stock stepup springs and rods. I tryed .73 by .42 rods and that night it ran like crap. I don't know because my truck hasn't ran the same since. I currently run a 670 street avenger.
68cabby
17
Jun 9, 2012 07:59 PM
Duke78
Paint & Bodywork
Nov 24, 2007 02:45 PM
385seriesHemi
Feb 2, 2007 02:56 PM
ClemsonLightning
Jun 22, 2004 08:30 PM
Vampiro
Aug 29, 2002 09:26 AM
