600 cfm too much?
Old Jun 8, 2012 | 01:03 AM
68cabby's Avatar
68cabby
600 cfm too much?
Hey guys..jw..I found an edelbrock 600 cfm for 125$ is 600cfm took much?
Old Jun 8, 2012 | 03:51 AM
Opossum's Avatar
Opossum
In general yes, but there are many factors that you haven't mentioned, is the engine stock? What manifold? What do you do with the truck? etc
Old Jun 8, 2012 | 10:08 AM
68cabby's Avatar
68cabby
Aahhh ok..some history would be in order well..it is stock. Rebuild 48000 miles ago. My 360 Fe blew up so my friend offered his old 300 in his shop. Only been sitting a year or so. I ordered an offy c intake and dual efi manifolds. Other than that a t18 will be backing it up and..there ya go
Old Jun 8, 2012 | 11:40 AM
Opossum's Avatar
Opossum
Sure you can do it, it will run, you can drive it but other options will work better. You'll just have to be careful on the throttle and tune it really well.
I don't know your manifolds well but assuming a 4bbl intake then that should work fine.
Edelbrocks are easy to tune the basics but not all that tunable, get some springs and metering rods and you should be ok, but they have poor idle circuts and accellerator pumps that are allways going to limit your throttle response with a carb that big of that make on that engine.
Run it if it's what ya got, but if your manifold is set up 4bbl, I would keep an eye out for a 390cfm holly 4bbl, dual pump, manual, with 4 corner idling. They are popular in circle track circuits but usually don't have chokes, you'll need a choke.
If you can run a 2bbl on that manifold then keep an eye out for a holly 2300 390 cfm, great little carb for a motor like that.
If you have a bunch of old ford parts laying around, and can run a 2bbl, a motorcraft 2100 is also an ok carb, they have their issues, but might be free and will likely run better then that edelbrock. I'm pretty sure they will take many holly parts, jets, power valves, etc to tune them.
Old Jun 8, 2012 | 12:25 PM
68cabby's Avatar
68cabby
I have my motorcraft from my previous engine..its a 2 bbl but not sure of the approximate cfms
Old Jun 8, 2012 | 07:06 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
A 600 cfm vacuum secondary (or air flap like the Edelbrock) carb is no worry on a 300. Edelbrock supposedly claims internal differences, but the 500 cfm and 600 cfm carbs have identically sized bores/venturis. I wouldn't spend more or go out of my way to find a carb smaller than 600 cfm to avoid "over-carbing".
The secondaries are only going to open as needed, so 90% of driving will just be on the primaries. The secondaries may never open completely.
Before you install the intake fab up a plate to circulate coolant (heat) under carb/plenum area - it makes a huge difference in driveability.
And there's no easier time to change a cam than when the engine's on a stand in the garage...
Old Jun 8, 2012 | 08:04 PM
Harte3's Avatar
Harte3
What BVA said X2.
Old Jun 8, 2012 | 08:12 PM
Opossum's Avatar
Opossum
The secondaries are only going to open as needed, so 90% of driving will just be on the primaries. The secondaries may never open completely..
A yeah I disagree, you have a point about a true vacuum secondary carb, but not the edelbrock, that flap thing causes all kinds of crazy running and tuning issues and can't be tuned.
Old Jun 8, 2012 | 08:36 PM
68cabby's Avatar
68cabby
Ok..then I may go with the 600 then..
Old Jun 8, 2012 | 09:12 PM
68cabby's Avatar
68cabby
Does a vacuum or mechanical secondary matter?
Old Jun 8, 2012 | 09:14 PM
68cabby's Avatar
68cabby
And..will the stock mechanical fuel pump work to 600 cfm?
Old Jun 8, 2012 | 09:19 PM
Opossum's Avatar
Opossum
HUGE YES and yes
Old Jun 8, 2012 | 09:52 PM
68cabby's Avatar
68cabby
So..recommendations?
Old Jun 8, 2012 | 10:01 PM
Opossum's Avatar
Opossum
Save your money and use the motorcraft you already have.
Old Jun 8, 2012 | 10:50 PM
68cabby's Avatar
68cabby
And if this motorcraft is a franken carb with a holley bottom and motorcraft top? It's all jerry rigged and there's not a stamping or number to be found on it..I pulled it from the shelf today and inspected it for like 30 minutes checking all the common marking spots and then some. I'm not sure how many cfms it is..it came from my 360 Fe. Plus..the c intake..with adapter..will work with two barrel...but I looked at the flow chart on tips and tricks and the c intake has a little ridge to divide flow from a 4 Bbl...anyone ran a 2 on an offy c intake before?
