cfm calculation
Old Nov 23, 2007 | 06:23 PM
Duke78's Avatar
Duke78
cfm calculation
I am wondering how to calculate CFM for compressors. If i have a compressor that delivers 11.5 cfm at 40 psi and 10.2 cfm at 90 psi then what is the cfm at 23 psi?
I'm really hoping that this compressor will work for some HVLP guns...
Old Nov 24, 2007 | 07:14 AM
MBDiagMan's Avatar
MBDiagMan
I don't know how you would calculate it, but it will be VERY close to the 11.5 number. There are many guns that will work at 11.5, but the very best ones won't unless you are doing panel work, rather than a complete paint job.
If you are looking for an economy gun, or a Mini gun there will be plenty that will fall into this area. If you are looking to run a high end SATA or something, then you will need more air. Do you have a smaller compressor that you could temporarily TEE together with the big one to add that couple of extra CFM that would run a SATA?
What gun do you have your eye on?
I ganged a 10.2 @ 90 together with a 6.2 @ 90 so that I can run a SATA type gun.
I know this is not the answer you were looking for, but I hope it helps.
Old Nov 24, 2007 | 09:30 AM
Duke78's Avatar
Duke78
Actually it's a fine answer, I had my eye on the DeVilbiss finishline, it requires ~12cfm at 23psi. I found a few that were in in 10-11 range aswell... I do have another compressor to gang with, its 6cfm at 90. Even though i'd like to not have to gang, it'd be great to just buy the right compressor to do everything but the cost, as usual, is an issue. I'm thinking the 11.5 cfm at 40 psi with 60 gal tank will be a great starter compressor and will run everthing well except maybe an SATA HVLP spray gun.
Old Nov 24, 2007 | 02:45 PM
MBDiagMan's Avatar
MBDiagMan
It sounds as if we are in the exact same situation. Read my thread entitled "Ganging Two Compressors Together?" Due to limited floor space in my shop, but not much limit to wall space, I built a platform to hang my 20 gallon, 2HP compressor on the wall above my 3.2HP compressor that is probably just like yours. I then ran black pipe with proper condensation drains and risers to allow for DRY as well as adequate volume of air. I now have enough air to run a SATA or whatever I want, and it's DRY air.
I too really wanted to buy an IR Type 30 and have a big compressor that would last the rest of my life, but for a LOT less money, I now have enough air and a very good dry air plumbing system as well.
BTW, don't plan on 12CFM @ 23PSI out of your compressor. Do a little work and plumb your compressors together. With a ball valve at the output of each compressor, you can run one of them for regular needs and then only turn on both and open the ball valves to both when your painting or blasting.
Go to TPTools.com and poke around on their website to find their write up on how to properly plumb an air system.
cruiser456
15
Jun 19, 2016 11:06 AM
savag
Feb 24, 2011 03:56 AM
daves54
Garage & Workshop
Dec 10, 2009 01:06 PM
66 twin i
Garage & Workshop
Sep 11, 2009 12:35 AM
1979_F100_302
Paint & Bodywork
Mar 28, 2004 05:39 PM
