Electric Fan CFM?
Old Jun 21, 2004 | 10:07 PM
ClemsonLightning's Avatar
ClemsonLightning
Electric Fan CFM?
Installing an electric fan on my 94 Lightning, how many cfm do I need?
Old Jun 22, 2004 | 10:09 AM
ridin93's Avatar
ridin93
Nor sure about CFM, but a freind of mine used a set of fans from a Dodge Intrepid, says they work good..It is a dual fan set up. I just biught a 2000 Mustang GT fan that I might install on my 93 Lightning. How are you going to wire it up??
Old Jun 22, 2004 | 11:06 AM
5_labsownus's Avatar
5_labsownus
Look at www.flex-a-lite.com, on that site you will find info about CFM and the fan sold for a vehicle and it's CFM.
On my 1982, 300 l6 I used a Flex-a-Lite 295. I think the 290 may be the fan for 97 and up.
Old Jun 22, 2004 | 05:07 PM
ClemsonLightning
I think I'm going to wire in a thermostat, and also an manual on switch. I don't really I want the fan to run ALL the time the A/C is on, so I'll use the manual switch to just turn it on if I need it. But it will always come on at 180 degrees F.
Old Jun 22, 2004 | 08:30 PM
ronsc1985's Avatar
ronsc1985
If you are going to use a thermostat then put the biggest fan you can fit on the radiator. You can always shut if off but on a really hot day under heavy load more is better. The only thing to watch is some of these fans use a lot of currrent, like 20 or so amps. Most all fan manufacturers publish both the cfm rating and the current draw. If they don't steer clear of them.
IHF250fireman
30
Aug 15, 2015 08:07 PM
TheFoum913
Dec 29, 2013 01:11 AM
4 rings
Oct 18, 2013 11:53 AM
CdnWillyG
Aug 11, 2012 09:13 PM
wicat3
15
Feb 14, 2012 10:04 PM
