AOD leaking Shift Shaft Seal
Old May 28, 2004 | 05:27 PM
broncobasher's Avatar
broncobasher
1990 F150 4x4 AOD
Does anyone know if the shift shaft seals can be replaced without dropping the pan? The exploded view looks like you have to take the shaft loose from inside, but I am not sure. Also, does anyone have any suggestions on getting the filler tube to stop leaking? I replaced the o-ring and it still wants to leak.
Thanks,
BroncoBAsher
Old May 28, 2004 | 08:45 PM
Jimbeaux's Avatar
Jimbeaux
Yes, unfortunately you have to remove the pan to change the shift shaft seal on an AOD because that is the only way to get the shaft out. I did anyhow. For the filler tube--you might try looking at heavier teflon o-rings from an AC o-ring kit to get a better seal. It should have been a pretty tight fit though with the correct part. Are you sure you got the correct o-ring?
annaleigh
May 17, 2017 07:08 PM
nolan62
15
Nov 27, 2016 01:47 PM
jimpennycuff
Feb 19, 2007 04:07 PM
broncobasher
15
Feb 18, 2007 11:50 AM
cabronco
1966 - 1977 Early Broncos
May 17, 2004 04:10 PM
