1978 - 1996 Big Bronco
TopLess - I did
Old Jun 25, 2004 | 05:50 AM
  #31
3broncocrazy's Avatar
3broncocrazy
Originally Posted by ubermich
Actually, what I did was this:
I put 2 2x4s across the rafters of my garage (to distribute weight across the rafters), then dropped rope from those and tied it via a boatman's knot (so it definitely won't drop).
When I want to take the top off, I lift one end, slide a 2x4 under it, life the other end, slide a 2x4 under... Then lift the 2x4 ~6-9" into the hanging rope. Once that's done it's just a matter of driving the truck out and lifting the 2x4s over the tire.
I may wind up replacing the 2x4s with steel bent to accommodate the tire or cut and piece 2x4s together so they'll have a _____/~~\__ shape to go over the tire...
But it's super-easy to get it up onto the 2x4s by myself, and cost me about $20.
i do something very similar. I used swing set chain (the kind with plastic coating - so no scratches) instead of rope, and 2"od metal pipe instead of 2x4s.(i already had the items so no cost) I cut the two pipes at a lenght so about 4" sticks out on each side. I get inside the bronco and lift the top with my back while the kid or wife inserts the pipe into the other side chain. I tie off the top to the mounting holes, hold the tire carrier open while the 10yr old drives the bronco out from under it
Old Jun 25, 2004 | 05:39 PM
  #32
freak98's Avatar
freak98
Here's my topless machine.
Old Jun 25, 2004 | 09:32 PM
  #33
PilotRob's Avatar
PilotRob
Top is off my '93 for the first time in its life.
Now I need a louder stereo.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
