I tried leaving my backseat in the garage (I like having the cargo space). Turns out though, when the top is off, everyone always wants me to give them a ride, and they all want to sit in the back seat
I have a 92 Eddie 4x4 and I noticed that the seatbelts are attached to the top and there is a back light in the top as well. How did you disconnect these 2 things?
Thanks
I spent several hours drilling holes in the drywall ceiling of my garage, putting 2x4s across the rafters (to distribute weight), and dropping rope (and tying it)... but every day since then it's rained! (except for one night, when I had a date and really really really wanted to take the top off, but there were clouds to the west and a 70% chance of rain. Damn weather men.)
Do you guys have the rear tire holder? If so, do you take the spare off every time you take the top off, or do you have someone help you lift the top over it? Or...? I'm not sure I really want to take the spare off and on every time I take the top off/on, but I don't want to go around without the spare either (and I don't want to mount it inside because I like the look of it on the back... picky, I know)... just curious if anyone has done anything interesting...
Also, I'm planning on finishing my soft top tomorrow. Cost so far is under $50 and I've gotten everything from Home Depot.
Lucky, whish I had a 10 yr old to drive my... wait a minute... You sir, are insane.
Must be nice having an extra set of hands sometimes. I'm on my own though, unfortunately. And my garage is insanely small, but I'll try tying it open tomorrow!
I had my top off for a couple of months (april, may) but put it back on b/c i like the cold A/C and the look better with it on. Of course, now I want to take it back off again... I really need a lift for it in my garage. I can say that it's very easy with 2 people, and no need to do anything with the spare. it can just stay where it is. My girlfriend and I took mine off in less than 5 minutes (not including time to get all the rusted bolts out). I would advise getting new clips and oiling the bolts before you put them back in. I did that, and it was 100 times easier to get off the next time.
Ubermich: with a good lift system you can get that sucker off by yourself really easily. I have been thinking of rigging up a hoist and pulley system for mine.
-Josh
Actually, what I did was this:
I put 2 2x4s across the rafters of my garage (to distribute weight across the rafters), then dropped rope from those and tied it via a boatman's knot (so it definitely won't drop).
When I want to take the top off, I lift one end, slide a 2x4 under it, life the other end, slide a 2x4 under... Then lift the 2x4 ~6-9" into the hanging rope. Once that's done it's just a matter of driving the truck out and lifting the 2x4s over the tire.
I may wind up replacing the 2x4s with steel bent to accommodate the tire or cut and piece 2x4s together so they'll have a _____/~~\__ shape to go over the tire...
But it's super-easy to get it up onto the 2x4s by myself, and cost me about $20.
to all that are topless, just remember when you put the top back on to tighten the bolts from the top to the cab first, then tighten the ones from the top to the bed, otherwise it may leak...i learned that one the hard way
heh, for $20 that can't be beat. I was thinking of something along the lines of a pulley system like what would be installed in a boathouse (obviously not as heavy-duty) with a hand crank instead of a power hoist. The one I've seen done like that had metal clips that went under the top's edges instead of the 2x4's. nothing was crossing the 'bed' of the truck, so there's nothing to lift up over the spare. of course, it's much cheaper to just wait till someone can help lift it off :-).
Maybe I should have posted this on the "ghetto soft top" thread. Maybe I should just get some sleep and not post at all. But ...
We all hate the thought of drilling into our rides, especially the tailgate. Well, how different is the Bronco gate from the F-series? Yes, the obvious is the window, but what about width? height? Goodness knows plenty of boxes are yanked off the F-series so that a utility box can be thrown on, and those old gates are floating around somewhere. Drill the "spare" gate for using the soft top?
Perhaps this would be overkill, but if it works, it beats drilling. Thoughts?
