Sponsored by: Innova
how to mount whips
Old May 26, 2004 | 07:52 PM
RICE H8R's Avatar
RICE H8R
how to mount whips
i got a couple CB whips for my pickup the other day, and was wondering how to mount them. i want one on each front corner of the bed. i was thinking of just drilling holes in the front rail, tapping it, and screwing them right in. will this work? or is there a special mount to do this easier? thanx
EDIT: is there a way i could make a mount if i cant tap it?? i like to do things as cheap as possible (but still have it look ok) since i am short on $$ right now.
Old May 26, 2004 | 08:26 PM
BuiltToughF250's Avatar
BuiltToughF250
just wondering, do you have a tool box in the truck?
peppy's Avatar
peppy
You can drill a hole, just seal off the bare steal. If you for some reason cant, they make brakets for bed mounting. Make sure you meter out your standing wave, dont want to fry your radio.
Hers a few links that might help.
http://home.att.net/~wizardoz/cbmw/antenna_fabri.html
http://www.alfenterprises.com/cb_rad...nting_kits.htm
http://www.wearecb.com/
Old May 26, 2004 | 08:32 PM
BuiltToughF250
oh yeah- my friend had his whips too close to the cab and they started to wear off the paint, so be careful not to do that
Old May 26, 2004 | 08:33 PM
RICE H8R's Avatar
RICE H8R
yes, i do have a tool box. its one that sits inside the bed, "underrail" as i think some people call them. it is mounted on brackets about 3" away from the front of the bed.
Old May 26, 2004 | 08:36 PM
RICE H8R's Avatar
RICE H8R
what bare steel are u talking about? im not a genius when it comes to this stuff.
Old May 26, 2004 | 08:39 PM
peppy's Avatar
peppy
If you drill a hole through your truck, you will have unpainted steel exposed. Stuff will rust away fast once it rains and the moisture gets trapped in your mounting hardware. All ya really gotta do do is paint the edges of the holes.
Old May 26, 2004 | 08:40 PM
Matts72's Avatar
Matts72
when you drill, you'll chip the surrounding steel, youi probably won't be able to see the actual chips. They will find a way to rust though.
I'd recommend a Wilson magnetic base, its removeable, and it won't hurt the paint.
Old May 26, 2004 | 08:41 PM
BuiltToughF250
the bare steel where you drill the hole in the top of the box rail- you dont want it to rust- maybe put the whip through the hole and put some caulk through it to keep water out
Old May 26, 2004 | 08:43 PM
RICE H8R's Avatar
RICE H8R
k thanx for the info on the bare steel. i get what u mean now.
anything else i should do or keep an eye out for when doin this?
Old May 27, 2004 | 09:01 AM
propellerhead's Avatar
propellerhead
I had the stake pocket mounts in my Ranger. They worked great. I was able to remove them later without any damage other than a little scratch.
kuch73
Dec 1, 2011 08:47 PM
ford_girl08
1997 - 2003 F150
May 25, 2010 05:12 PM
AKFORD4x4
21
Aug 7, 2008 08:04 PM
Peter94
1983 - 2012 Ranger & B-Series
Jan 30, 2004 09:19 PM
stover007
Apr 27, 2002 11:06 PM
