alt idiot light brightness
Old May 24, 2004 | 07:15 PM
66f100352's Avatar
66f100352
Ok I have a 66 with the 352 it has a new battery and a new soild state voltage regulater but the alt light is only half it's brightness. So I cleaned all grounds and wires going to the reg and alt with my dremal and replaved the bulb still half brightness. I tested the socket it's at about 7.5 volts I tested the I termal on the reg for resitence and it's at about 8 ohms what could be causeing this??? The alt is putting out 14.25 at idle even under load what gives?
Old May 25, 2004 | 08:11 AM
Franklin2's Avatar
Franklin2
Sounds like the alt is working fine. I never knew there may be a difference in brightness between the old regs and the new solid state kind, but maybe there is. Nothing to panic over is it?
Old May 25, 2004 | 09:31 AM
66f100352's Avatar
66f100352
No nothing to panic over just very curious. I replaced the alt and reg last night just cause of age and the reg was under warrenty but still the same brightness it was like this with the old style reg as well. Oh well
1riverside
Mar 28, 2014 06:49 PM
autoxbird
May 5, 2012 08:43 AM
anderson sc
15
Oct 4, 2009 03:12 PM
caseydudem
21
Oct 19, 2007 08:11 PM
corkybarder
Jul 23, 2004 10:50 PM
