Alt. light on while still charging
Old May 1, 2012 | 11:30 PM
autoxbird's Avatar
autoxbird
'91 F250 Custom, 460. While about 200 miles from home (because problems always happen far from home), I notice the alt. light is on, at about half the brightness it has KOEO. The volt gauge on the dash is still reading normal, does the same sweep it always has, drops at idle, etc, all those 2G traits. Made it home fine, with the lights, fog lights, heater, stereo, wipers, and powering a trailer, with no issues. Why is the alt. light on?
Old May 2, 2012 | 04:20 AM
fdude64's Avatar
fdude64
mine does the same thing,there is a single wire going to a spade terminal on the back of the alt. that when it doesent make contact the light comes on
Old May 2, 2012 | 07:57 AM
subford's Avatar
subford
That would be a 3G, he said he has a 2G.
Old May 2, 2012 | 09:40 AM
95f2504x4's Avatar
95f2504x4
When I used to have my 89 6 cyl 4x4 it started doing the same thing. Then one day the battery light came on and the gauge started to go over normal. Popped the hood and my battery was leaking from the top around where you would fill it. Changed the alt out and it never did it again. Idk if the voltage reg is internal or external from the alternator or not but basically i guess it started over charging or something.
Old May 2, 2012 | 11:48 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
2G's are internally regulated.
It would be a good idea to put a VOM across the battery terminals while the engine is running and see what the alternator is putting out.
Bring the rpm's up to 2k or so and check again.
"Why is the alternator light on?"
Because there is a voltage difference across the two terminals of the bulb's socket.
Old May 2, 2012 | 12:06 PM
autoxbird's Avatar
autoxbird
So I got...
Idle, no load: 14.35
Idle, full load: 12.05
2K, full load: 13.71
2K, no load: 14.40
Old May 2, 2012 | 12:10 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
... and your alternator seems to be working fine.
I would check for dirty copper foil contacts in the bulb socket or some other reason for the instrument cluster not seeing full voltage.
Old May 2, 2012 | 12:18 PM
autoxbird's Avatar
autoxbird
I'll have to get some ambition up to do that, ha. (Yes, I know the cluster is simple to pull out)
It just seems odd that it would start out of the blue.
Old May 2, 2012 | 01:40 PM
Jaime74656's Avatar
Jaime74656
thats when problems start to happen and things break...out of the blue but I do agree with what was said by Ard...I did have the same issue (in a different foreign made car that is now driven by my younger brother) and when the same type of behavior started it wound up being the alt its self showing signs of break down and then just one day died...
Old May 4, 2012 | 11:11 PM
autoxbird's Avatar
autoxbird
So I'm thinking the old girl was trying to give me a warning. Noticed the dash volt gauge was looking lower at idle, and acting odd at revs. Got home and retested it...
Idle load: 11.95
Rev load: 13.01
Idle no load: 12.41
Rev no load: 13.32
Fortunately, I just happened to get my hands on a 3G, from a '97 3.0 Taurus. Unfortunately, I need to tow the race car tomorrow at 10:30 AM. Tine to get swapping...
Old May 5, 2012 | 05:57 AM
ncranchero's Avatar
ncranchero
Bad diode in the diode trio was the cause on my Crown Vic. IDK if that may be the same here?
Old May 5, 2012 | 05:59 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Diode will cause it to backfeed but won't usually stop it from charging.
Old May 5, 2012 | 08:43 AM
ncranchero's Avatar
ncranchero
As I understood it in the original post it does still charge. My CV continued to charge also.
Campos02
Jun 22, 2019 04:11 PM
agg_bagg
19
May 9, 2018 10:43 AM
Dufftrucks
Sep 20, 2011 03:05 PM
Tex1986
1997 - 2003 F150
Feb 16, 2011 04:08 PM
in2racin
Dec 7, 2010 11:32 AM
