302 351w
Old May 23, 2004 | 10:06 PM
N-videto's Avatar
N-videto
302 351w
Hi guys can anyone out there how to tell a 351 w from a 302?
Old May 24, 2004 | 12:03 AM
Jimbo302's Avatar
Jimbo302
The deck is taller, so the intake on a 351 is wider by a few inches.
Old May 24, 2004 | 10:58 PM
Silver_Bullit's Avatar
Silver_Bullit
As Jimbo302 said, the deck is taller on a 351W. If yu ook at a 302, the deck will be even with the water pump. On a 351W, the deck is about 1" taller than the 302.
Old May 25, 2004 | 08:39 PM
84FB351's Avatar
84FB351
i beleive the 302 intake is about 9-1/2 inches wide and the 351w is somethin like 11 inches give or take
Old May 30, 2004 | 09:38 AM
jrocco's Avatar
jrocco
The Windsor engine weighs about 510 lbs in factory trim compared to the 460 lbs of the small block 289/302. The 351 version of the Windsor added approx. 1/2" to the deck height of the small block . The easiest way to spot a 351W Block is to notice the difference in height between the intake gasket surface and the top of the timing cover at the front of the block. I can get three fingers between the water neck on the intake and the timing cover on a 351W and only two on a 289/302. The 351 uses a longer connecting rods than the 289/302, therefore the reason for the taller deck height. This in effect reduces excessive piston side loads. The 351 Windsor's deck height is 9.480" for (1969/70) and 9.503" for (1971/96).which is the same as the 400M, compared to the small blocks 9.2" deck height.
briank
15
Oct 18, 2008 11:07 PM
Ozzie
23
Oct 30, 2007 12:47 PM
v10squirrel
Jul 10, 2007 08:54 PM
stover007
Mar 16, 2003 09:34 PM
billyb
Apr 28, 2001 09:50 PM
