Coolant additive
Old May 14, 2001 | 04:29 PM
Gr8ride's Avatar
Gr8ride
Coolant additive
Hi,
I posted a question a few days ago and some of you guys said to only buy a truck if the owner has used a coolant additive.
I am wondering if I buy one were they havent used an additive, how long do you think the engine will last if I start useing an additive in it. I am looking at an 89 F250 with 130,000 miles on it.
Thanks,
Richard.
Old May 15, 2001 | 01:37 PM
powerstroker250's Avatar
powerstroker250
Coolant additive
You might do a coolant system pressure check for starters to check for cavitation, check coolant for oil and oil for coolant. If the engine has 130k on it and the FW-16 wasn't added I don't think I would buy it. I don't believe there is an easy way to see how much if any damage has been done. I have heard the engine can start cavitating as early as 70k.
Les
Old Aug 15, 2001 | 08:30 PM
catfish's Avatar
catfish
Coolant additive
I am curious about the coolant additive fw-16? Where do you get it, what does it do, How often do you add it, Howoften should your coolant be changed? I would appriceiate any help you could offer.
Thanking you in advance for any help you could give me concerning this mater.
Old Aug 15, 2001 | 09:42 PM
snakebite's Avatar
snakebite
Coolant additive
FW-16 is a coolant additive that is offered by your local dealership. The FW-16 is not a product, but a motorcraft part number for a product. It is always great to us a factory certified product but there are also several name brand manufacturers out there that offer coolant additive at local parts stores. It is hard to say when to change your coolant. This can only be determined by the severity of the duty that the truck is worked. Try adding the coolant additive atleast twice a year. It is a very cheap alternative to engine failure.
Old Aug 16, 2001 | 04:28 AM
The Diesel Dude's Avatar
The Diesel Dude
Coolant additive
We did a study at the plant on cavitation in the 6.9/7.3 IDI engine and the conclusion was that cavitation wasn't much of a problem except on severe service engines. The harder they were worked over a long period of time the more likely they were to suffer the effects of cavitation. Navistar school buses were the worst.
Old Aug 16, 2001 | 05:51 AM
fordiesel69's Avatar
fordiesel69
Coolant additive
I agree with Joe, If the guy only used it as a daily driver and used it to haul small loads, Then I would go for it. If it was used to pull a 5th wheel or anything heavy then I would have second thoughts.
1986 F-250 6.9 diesel,4x4,XLT Lariat,Ex Cab, 8'bed,etc...
Old Aug 16, 2001 | 10:56 AM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Coolant additive
joe, what exactley is 'cavitation'?
Is it oxygen pitting of the metal, or caused by turbulent flow? Is the factory additive an oxygen scavenger, or a corrosion inhibiter?
I'm curious, because when we speak of cavitation at work, we are reffering to a centrifugal pump that has lost it's suction head or the fluid is beginning to flash to gas inside the pump. This causes either surging or complete loss of output and can lead to damage of the mechanical seals.
Scott
Old Aug 16, 2001 | 02:59 PM
rob_nc's Avatar
rob_nc
Coolant additive
Scott, this link should answer your questions.
http://www.freeautoadvice.com/diesel/cav.html
Rob
Old Aug 16, 2001 | 03:04 PM
rob_nc's Avatar
rob_nc
Coolant additive
Heck, that site has alot of good info for any PSD owner. It's worth a look at.
Old Aug 16, 2001 | 07:04 PM
horsepuller
FTE Emeritus
Coolant additive
rob_nc, thanks for the link.
Okay, I understand now. We use the same type of chemical treatment program on our high pressure steam boilers at work. When we open them up for inspection, they are covered with a nice soft black residue, which is good. If it's red, that's bad.
Wihout the proper chemical protection, the interior walls of the steam generating tubes will get pitted from the water flashing into steam. (Sort of a crater from a mini explosion).
PSD:
P ressure
S team
D egenerator
Thanks,
Scott
Old Sep 30, 2001 | 06:19 PM
willpower250's Avatar
willpower250
Coolant additive
The manual says to add coolant additive every 15000 miles. Will it be detrimental to the motor to add the additive without using the test strip that I have heard so much about. Thanks from a new PSD owner.
Old Oct 1, 2001 | 01:45 AM
The Diesel Dude
Coolant additive
The 2002 Power Strokes Do not require the additive any more. For 2002 Ford went to Texaco OAT Long Life Coolant. (I'm not sure what OAT stands for.)
Old Oct 1, 2001 | 04:21 AM
argve's Avatar
argve
Coolant additive
overdose of additive is bad as well. Use the test strips and they will tell when you need to boost the system.
1991 F350 CC Dually 7.3l, E40D, Soup bowl removed, K&N
Old Oct 2, 2001 | 09:43 PM
MeanOlBill's Avatar
MeanOlBill
Coolant additive
twom7
32
Oct 5, 2012 02:57 PM
RocknXJ
19
Jul 8, 2007 09:36 AM
Peter Richards
Jun 16, 2007 09:50 PM
HDMustF250
16
Apr 9, 2004 10:01 AM
Gr8ride
May 17, 2001 01:53 PM
