IDM or Injector?
Old May 20, 2004 | 11:04 PM
IowaF250's Avatar
IowaF250
IDM or Injector?
After spending most of the morning at my local ford dealer I learned one thing.
With all the computers in the truck and in the shop, it all comes down to one thing.
A “WAG” (wild *** guess).
We did a cylinder contribution test; found that # 6 cylinder is giving me the problem.
Plug the “computer” back in and look for codes. Everything looks like I have an injector
going out (if not out altogether). We find a code P1298 “replace IDM” ($875 part $275 labor) I’m told “this may or may not work, you might still need injectors ($320 per + labor)
I asked “if we replace the IDM and that’s not the problem then what? Am I out $1150”?
Sorry to vent to all of you, has anyone ever run into this problem?
I’m thinking about trying fixing the # 6 injector and if that’s not it then replace the IDM.
(If you have a ’99 PSD don’t pay $275 labor having them fix it. Take the black plastic off around the inside of the drivers side front wheel well and look up. It will take you about 10 – 15 minutes to do this whole replacement)
Old May 21, 2004 | 10:58 AM
subdewd's Avatar
subdewd
I would think that if you took it in and told them to fix it then they would be
responsible for any misdiagnosise. After all thats why you paid them and didn't
do it yourself.Otherwise I'd contact your attonney general and file a fraud complaint.
Old May 21, 2004 | 04:57 PM
homer4111's Avatar
homer4111
i have a 99 and am going through the same thing i took a idm off my other truck and #4 still dosent fire till truck warms up. but when warm cyl contr test shows all fine.i have 5 7.3 trucks the only time i got idm code was when i had bad harness to injector and even then i got a high to low circuit open. i would change the injector first.
Old May 21, 2004 | 11:09 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Do not allow the stealer to overlook the one thing that connects the IDM to the injectors. A bad/burned injector wiring harness can make either component look bad.
Plus the harness costs less than a single injector.
Old May 23, 2004 | 09:02 AM
IowaF250's Avatar
IowaF250
Well I replaced the # 6 injector, and MAN this thing runs great.
Thanks for all your input.
Cheers
Old May 23, 2004 | 10:18 AM
homer4111's Avatar
homer4111
how much did they get for rebuilt injector? i think ford here quoted me like 350.00 for the part
Old May 23, 2004 | 12:46 PM
IowaF250's Avatar
IowaF250
If you go to a International dealer they charge $225.00.
Hell I had mine installed cheeper then your cost, try the international shop first.
Old May 23, 2004 | 02:59 PM
homer4111's Avatar
homer4111
did they ask for a engine serial number . i have heard that they get sour if you tell them its in a ford.
Old May 24, 2004 | 11:37 AM
99PSDCREW's Avatar
99PSDCREW
IowaF250,
How much did that cylinder contribution test run? Thinking of doing that also just to be on the safe side.
99PSDCREW
Old May 24, 2004 | 06:18 PM
homer4111's Avatar
homer4111
i used my snap on mt 2500 i would do it for ya free if you were in nj. a shop here would charge like 65.00
Old May 25, 2004 | 01:31 PM
IowaF250's Avatar
IowaF250
99PSD;
I used my own tester (snap-on), a friends tester (snap-on), and I had ford do it. They charged me
$50 to put their tester on. They had to eat the labor (side bet) because
they told me my tester was a piece of crap and I wold only get a true look at
my problem with a quality tester, "not a cheep piece of crap like that". I thought that was a good deal.
Cheers
Old May 25, 2004 | 05:23 PM
bodabdan's Avatar
bodabdan
Veteran: Navy
Cheap Snap-On?
Whoever told you that has obviously not priced Snap-On tools in a while.
Old May 25, 2004 | 06:35 PM
homer4111's Avatar
homer4111
im not sure what they use but the snap on tester is pretty damn accurate. how did their results differ from the crappy snap on scanners?
gregorymw
16
Aug 31, 2012 09:05 PM
tjbeggs
16
Mar 17, 2011 12:34 AM
fixnair
Feb 20, 2011 08:22 PM
Vankaye
Jul 22, 2010 10:20 AM
tjbeggs
Jan 31, 2006 06:00 AM
