460 Specs?
Old May 19, 2004 | 12:32 PM
tmdata's Avatar
tmdata
460 Specs?
Just bought a 1994 F53 460 EFI motorhome and I am looking to tune it up.
I'm looking for some general specs and preferences for this engine; oil capacity, recommended oil weight, synthetic or blend?
Plugs? Anyone getter any better performance out of platinum or dbl platinum plugs? I am happy with platiniums I run in my 302 (5L).
Any website for this general info for this year?
Thanks
TomD
Old May 19, 2004 | 01:37 PM
jim henderson's Avatar
jim henderson
My experience with my 94 460 is that the standard non platinum plugs look like heck after 35K miles. They also are a beach to remove. I think next time I will try some platinums and preferably use something with a chrome or stainless(do they make that?) thread. In any case use some antisieze since I think with high heat, the plugs get stuck pretty good. I tow 8,000# and am pretty sure things get hot under the hood, although coolant temps are fine.
I think if I can get a thread chaser in there, I will do that next time before putting new plugs in.
I use Valvoline 10W30 synthetic, 6 quarts with new filter.
Good Luck,
Jim Henderson
Old May 24, 2004 | 01:45 PM
renelson177's Avatar
renelson177
Although I prefer to run Mobil 1 15W50 for those hot, summer towing runs I would definetly recommend (as does our dealership) using the Ford FL1-HP oil filters on 460's. High capacity, higher pressures and built for racing engines. The 460 delivers a lot of pressure, especially on start up with a cold engine.
__________________
Roger
Clyde S Dale - 1984 F250HD 4X2 460-C6-3.55
5th Wheel Towing Workhorse.
63,000 original miles
54LFL
Jul 15, 2017 08:30 AM
Skidooer16
Nov 10, 2016 03:49 PM
waylen89
Jan 23, 2016 05:35 PM
RobertH
Jun 30, 2014 05:08 PM
460v10
Aug 26, 2001 07:44 PM
