New life in a '53
Received 1,364 Likes
on
on
Originally Posted by fomoko1
What engine did you decide to go with?
Jag Red 54 I will not put in a chevy in there, I have see it done, it look;s "very lame!!"
PS: If you have a copy the new (July 04) CUSTOM CLASSIC TRUCKS look @ page no# 88 pic no: 5 and that is what I would like have or something like it and having it look old school lol!
Old Skule is Good
I have a 5.0L/AOD from an '86 Lincoln Mk.VII with an 8.8 & 11" drums from an '85 Country Squire out back.
Seems to work real well with lots of room to spare! You can get bolt in tranny mounts as well. You may get lucky as I did and have the drive shaft from your donor vehicle bolt in with the help of a spacer or you may have to shorten your shaft and have it rebalanced.
The 5.0L is the same block as the 302 with the carburator swapped out in favour of fuel injection... see the FTE Forum on that subject for discussions of pro's & con's of the two fuel delivery systems.
... and have fun with your project
GW
GW
If that, dose work I know where I can get a late 80’s Ford Crow Vic LTD, for about 750.00 with 302, EFI but I would have to rebuild the engine due to that it has been sitting for about six to seven years. I don’t know if that would be good for an engine or transmission by sitting that long and not be running at all!! Pulse it is my dad's aunt’s car, she does not drive it at all any more I would like to put it to some good use and not having it go to waste. If you know what I mean? <O</O
<O</O
Talk to you all latter,<O</O
<O</O
Quiksilver <O></O>
<O</O
<O</O
Quiksilver <O></O>
on
Originally Posted by quiksilver
Thing of the 302 or the 351. Also if I did go with the 351 would I have to make the drive shaft shorter and could I still use the old rear end it has I think a 8.8 with 3.9.1 gears??
Originally Posted by tacson
Hey guys,
I have a 1987 5.0L and AOD out of a Crown Victoria. It is EFI the speed density type not Mass Air like on the 5.0 Mustang. It gets 22 MPG. Thus far I have been driven to Atlanta and the Nationals last week from my home base in Nashville.
Are you running the original guage cluster? How did you hook the tranny to the speedo?
LMK
GW
