Engine Hesitation
Old May 17, 2004 | 08:35 PM
mick w's Avatar
mick w
Engine Hesitation
Howdy out there in FORD LAND.
I am new to your forum, but I would sure appreciate some help. I just installed a new 2.9 long block in my 90 Ford Ranger and everything went well, but I have a hesitation when I am driving it. This is an occasional thing, but sometimes it worse than others. I have checked fuel pressure, and it is fine. I have also put in a new rotor, distributor cap, plugs, plug wires, and a new coil. I also cleaned the fuel tank and added a new fuel filter.If anyone out there can help me find the solution for this problem I would sure appreciate it.
Thank you much Mick.
Old May 17, 2004 | 10:47 PM
mrshorty's Avatar
mrshorty
I would start by running the computer self-tests. It can be tough diagnosing these intermittent faults, but there might be a fault that the computer can see/has seen that can point in the right direction.
Old May 18, 2004 | 12:45 AM
AG4.0's Avatar
AG4.0
Is your hesitation like a sudden loss of power that jerks you forward in your seat momentarily and then keeps going like nothing happened until it does it again 5 minutes later. That's the issue I had with my 89 BII. I figured it was due to the 195K it had on it. Took it to a mechanic to have it checked out, and of course I could not get the damned thing to do it. They did a diagnostic on it and came up with no codes and charged me $50. Oh well. Good Luck.
mick165
2004 - 2008 F150
Sep 12, 2013 09:50 PM
WillyB
N. California Chapter
Feb 27, 2008 02:25 AM
mick460
Aftermarket Products
Feb 13, 2003 06:21 PM
mick460
Sep 2, 2002 09:22 AM
