misfire on hard acceleration
Old Jan 12, 2013 | 03:07 PM
mick165's Avatar
mick165
F150 2005 Lariat 5.4L 242 000 km (150 370 mi)
on very hard acceleration i got a P0307 misfire.
what i did :
---new cop
---new plugs
---clean MAF
---new fuel filter
---swap the new cop with another new that was on #5 and still getting p0307
also have a little stumble when idling at a stop but no CEL
also have a long to start issue when staying for a while (fuel pump and module have supposly been changed by the previous owner)
any suggestion, please help
Old Jan 12, 2013 | 08:19 PM
CelticDevilDog's Avatar
CelticDevilDog
Just out of curiosity were the plugs torqued to factory specs?
Old Jan 12, 2013 | 08:43 PM
JWC 3's Avatar
JWC 3
Ck #7 injector . I think that this is one of the years they had problems . They can leak down after shut off and cause the hard start . They can also cause missfires . Switch injectors and see if miss follows the injector .
Old Jan 12, 2013 | 08:51 PM
mick165's Avatar
mick165
plug not torque but ok and i'll swap inj and check after I'll let you guys know
Old Jan 13, 2013 | 11:37 AM
SCRWDRVR's Avatar
SCRWDRVR
"Obsessed"
I would try swapping a plug to see if it follows first you could have a bad one....
Old Jan 15, 2013 | 12:04 AM
mick165's Avatar
mick165
swap the injector and the spak plug and roadtest this ****ing truck and the misfire didn't move.. still on cylinder #7 p0307+p1000
any suggestion?
Old Jan 15, 2013 | 02:02 AM
curtk69's Avatar
curtk69
im getting this or similar problem too.
previously it was idling rough/had misfire.
changed plugs, one had a completely burned off electrode, might have been #7 cylinder, which one is that?
now it idles nicely but still has a bogdown problem or runs rough if i try to drive away w/o a good warmup here in cold canadian winters.
was gonna try a new injector in the same cylinder i found the bad plug in. i think it was the front right cylinder whichever number that was?
how does one change a injector on these 5.4l 2006 year?
Old Jan 15, 2013 | 07:04 PM
JWC 3's Avatar
JWC 3
V8 ,Ford ,driver side front cyl. #5 1-4 pass side front to back . Driver side 5-8 , front to back .
Old Sep 12, 2013 | 10:54 AM
mick165's Avatar
mick165
change fuel pump for long start issue and ok for that and t=did the exhaust manifold on left side and saw that the ex valve was all white on #7 sa if the cyl run lean! any suggestion?
Old Sep 12, 2013 | 09:50 PM
skunkoffroad's Avatar
skunkoffroad
Check the injector harness. If that's not it do a compression check. My 2¢
Brett_N
Aug 10, 2017 09:39 AM
hatchet
Sep 4, 2010 07:11 AM
lawnboy58
Bronco II
Oct 3, 2008 11:59 PM
ptesmoke
1983 - 2012 Ranger & B-Series
18
Oct 1, 2008 11:57 AM
calhounsF250
Jul 5, 2006 11:48 PM
