desktop dyno plz.
Old May 12, 2004 | 09:14 PM
throtle jocky's Avatar
throtle jocky
desktop dyno plz.
could somone run my combo on there desktop dyno for me please.
i'ts a 351w
bored 0.030" over
9.5-1 compression
edelebrock victor jr heads
edl perforfer rpm intake (port mached)
holly dp with proform 750cfm main
1.6 rr
comp xe274h-10. 274/286,230/236@0.050", lift is I.519 E.523", lobe sep 110
1 3/4" long tube hedders (not compleat yet)
the cam is set strate up I have eagle I beam rods and speedpro forged pistons. This is going in my 76 f-150 4x4
Old May 13, 2004 | 07:24 PM
Fully_Loaded's Avatar
Fully_Loaded
Valve size for a more precise calculation?
Old May 13, 2004 | 07:44 PM
Fully_Loaded
This is what I ran with a random exhaust, and valve size. Also I am not sure if your intake is single or duel plane
1000
6000 RPM
10000
2000
8000
4000
Torque (ft-lbs)-Dynol
Power (HP)-Dynol
Dynol
Page 3 of 5
Dyno2000 Version 3.10
CALCULATED POWER AND ENGINE PRESSURES
Engine RPM
Power (Fly)
Torque (Fly)
Int Man Pressure
Vol Eff%
IMEP Pressure
FMEP Pressure
BMEP Pressure
2000
146
383
14.67
70.9
211.0
17.4
164.0
2500
191
401
14.65
74.5
210.9
18.8
171.5
3000
237
414
14.63
77.2
214.2
20.3
177.1
3500
286
430
14.59
81.2
218.5
21.9
183.8
4000
334
439
14.55
84.3
222.7
23.6
187.8
4500
378
441
14.49
85.8
225.3
25.5
188.5
5000
411
431
14.43
86.0
223.1
27.4
184.6
5500
430
410
14.38
84.9
215.6
29.5
175.6
6000
434
380
14.33
82.2
203.8
31.7
162.4
6500
431
348
14.29
79.6
191.8
33.9
149.0
7000
408
306
14.25
75.4
175.0
36.3
130.8
7500
380
266
14.24
70.9
159.6
38.8
113.9
8000
339
222
14.24
66.3
142.2
41.4
95.0
8500
298
184
14.24
61.9
127.8
44.2
78.8
9000
252
147
14.25
57.9
113.6
47.0
62.8
9500
203
112
14.26
54.1
100.8
50.0
47.9
10000
154
81
14.28
50.8
89.8
53.0
34.7
10500
98
49
14.29
47.8
78.5
56.2
21.0
11000
40
19
14.30
44.6
68.2
59.5
8.2
Dynol
Page 1 of 5
SHORT BLOCK
Block: Ford 351 Cylinders: 8
Bore: 4.032 in CylVol: 732.32 cc
Stroke: 3.500 in Total Vol: 357.5 ci
CYLINDER HEADS
Cylinder Heads:
Edelbrock Victor Jr.
Airflow File:
Edelbrock Victor Jr.flw
Intake Valves:
1 Exhaust Valves:
Intake Valve:
intake1 .600 in
exhaust1.730 in
COMPRESSION
Compression Ratio: 9.50 Combustion Space: 86.16 cc
INDUCTION
Induction Flow: Manifold Type:
750.0 cfm @ 1.50inHg Single-Plane Manifold
Fuel: Gasoline N20: O.OIbs/min
Blower: None Flow: *** cfm Speed: *** rpm Eff: *** %
Pressure Ratio: *** Belt Gear Ratio: Internal Gear Ratio: ***
Intercooler: *** % Boost Limit: *** psi Surge Flow: *** cfm
EXHAUST
Exhaust System:
Small-Tube Headers Open Exhaust
CAMSHAFT
Camshaft Type: XR274R Lifter: Roller Cam Specs @: Seat-To-Seat Int Lift@Valve: 0.602 in Exh Lift@Valve: 0.608 in Nominal Timing
Cam File: XR274R.cam Lobe Center: 110.0 Valve Overlap: 57.0 Int Duration: 274.0 Exh Duration: 280.0 Timing© Adv(+)/Ret(-): 0.0
IVO (BTDC): 27.0 IVC (ABDC): EVO (BBDC): 70.0 EVC (ATDC): ICA (ATDC): 110.0 EGA (BTDC):
67.0 IVO: 27.0 30.0 EVO: 70.0 110.0 ICA: 110.0
IVC: 67.0 EVC: 30.0 EGA: 110.0
Old May 15, 2004 | 03:23 PM
throtle jocky
sory for the delay. the valve size is I 2.05", E 1.60", The ports on the intake are 210cc and the exhaust is 75cc. It's a duel plane intake, and lets say 1 3/4" x 18" primary hedders with 3" exhaust all the way back with flowmasters. I'm living at 7,200' ellivation right now. thank you for all the info.
Old May 15, 2004 | 05:55 PM
fordeverpower's Avatar
fordeverpower
the exhaust is 175cc but damn thats a serious 351w throtle jockey.
Old May 15, 2004 | 09:50 PM
Fully_Loaded
Here is the updated #s
Engine RPM
Power (Fly)
Torque
(Fiy)
Int Man Pressure
Vol Eff%
IMEP Pressure
FMEP Pressure
BMEP Pressure
2000
156
409
14.67
74.4
223.9
17.4
175.0
2500
201
422
14.65
77.3
221.0
18.8
180.5
3000
246
430
14.62
79.3
221.6
20.3
183.9
3500
297
445
14.59
83.4
225.6
21.9
190.4
4000
348
456
14.54
86.8
230.5
23.6
195.1
4500
396
462
14.48
89.0
235.0
25.5
197.6
5000
436
458
14.41
90.2
235.1
27.4
195.9
5500
464
442
14.35
90.2
230.1
29.5
189.3
6000
475
416
14.28
88.3
220.3
31.7
177.9
6500
477
385
14.22
86.0
208.5
33.9
164.7
7000
463
347
14.18
82.7
193.8
36.3
148.5
7500
449
314
14.15
79.3
181.2
38.8
134.3
8000
417
274
14.12
75.4
165.5
41.4
117.1
8500
385
238
14.11
71.5
152.1
44.2
101.8
9000
346
202
14.10
67.7
138.6
47.0
86.4
9500
304
168
14.10
64.1
126.2
50.0
71.9
10000
261
137
14.11
60.6
115.2
53.0
58.7
10500
212
106
14.12
57.6
104.2
56.2
45.3
11000
155
74
14.12
54.1
93.0
59.5
31.6
Old May 16, 2004 | 10:08 AM
Squiggy's Avatar
Squiggy
Desktop Dyno isnt the most accuarate measure even for a real dyno it has to be setup pretty good and the right programming for each vehicle. This is a rough estimate as you all probably know.
Old May 16, 2004 | 04:37 PM
throtle jocky
My NX hitmen nitrous kit just showed up. It came with jets for 100, 150, and 200hp. I heard somwere that NX rated there hp levels at the rear wheels. This truck should get moving nicely even with the 100 shot.
I found that my school (wyotech) has a engine and a chassie dyno in my roommates class. It will take me a few weeks to get it all set up but i'll post back with the results. at this elevation (7200') they say it brings the avrage hp down 25%, the air pressure here is somewhere between 11 and 12 psia.
JBradley500
Oct 22, 2010 11:30 AM
Karm239fh
May 19, 2005 07:07 PM
ford390gashog
Aug 22, 2004 12:22 AM
Sunfire_Stomper
Sep 6, 2002 03:54 AM
shazam
15
Feb 16, 2002 09:12 PM
