Bypass filter
Old May 11, 2004 | 11:19 PM
Fire Rooster's Avatar
Fire Rooster
Bypass filter
I have been reading a lot about the bypass filter for the oil. I am very interested and I know some of you all are using it. Give me the good the bad and the ugly on them. Are they really as good as they sound? How often do you send in oil samples to test it? How long do you all go between oil changes with it? How many more Quarts of oil do you need to add with it? How hard is it to change the bypass filter and how often?
Fire Rooster
Old May 11, 2004 | 11:22 PM
johnsdiesel's Avatar
johnsdiesel
I've been considering adding a bypass filter myself. If I do add one I am going to continue to change my oil at the same interval. I'm just interested in longevity, not extending oil drain intervals. The best setup I've seen so far is by Oil Guard (one of our sponsors). I'm probably going to buy one this summer.
Old May 11, 2004 | 11:26 PM
Fire Rooster
John
That is my main concern too is longevity, I change my oil every 3000 miles but if I can push it out to the recommended 5000 (buy the owners manuel) and feel comforted doing it with the bypass. Then it would pay for itself. I agree the Oil Guard does look the best. I just want to hear from those who use it if it is really doing what it claims.
Fire Rooster
Old May 11, 2004 | 11:50 PM
johnsdiesel
Have you checked out any of the toilet paper filters like Frantz? I haven't quite made up my mind on them yet. The price of the filter sure seems good though.
Old May 12, 2004 | 07:46 AM
HeatStroked's Avatar
HeatStroked
I installed the Oil Guard for filtration purposes only and not to extend oil change intervals. The Oil Guard filter is specifically designed to filter to 1 micron. The filter is a spun material meant for oil fitration, not a roll of Brawny.
Personally, if you're going for extended oil changes, (3000 miles +) I would consider synthetic oil with the Oil Guard or other bypass systems.
The engine on my PSD gets pretty loud and performance drops off as I exceed the 3000 mile mark.
I can't believe the PSD owners that claim to run their oil for 10's of thousands of miles between oil changes using synthetics and a bypass. Their claims are stated like it is some proud badge of honor because they saved a couple hundred dollars on oil changes. One thing the bypass oil systems and synthetics don't do is filter any liquid contaminants from your oil. Diesel fuel, coolant, etc. can contaminate your oil and reduce it's effectiveness and pass right through the filter. But, wow....they saved a few bucks!
Here are a few pics.....
http://community.webshots.com/photo/...42456246otRzyk
Old May 12, 2004 | 01:02 PM
CLK's Avatar
CLK
I also have the oil guard on my truck. As heatstroked said it is an element not a roll of toilet/paper towels, which is why i bought it. I am very pleased with the added filtration and how clean the oil stays. I do run synthetic but I change it every 5000 miles.
Old May 12, 2004 | 01:08 PM
johnsdiesel
I totally agree. The real reason a bypass system should be used is to extend the life of the engine. Extending oil drain intervals only negates the benefits of having a bypass filter.
Old May 14, 2004 | 12:28 PM
Fire Rooster
Thanks all,
I have learned some info I think . Any way I have decided to go with the bypass filter in the furure. I will stick with my regular oil change intervals still at 3000 to 3500 miles based on my time availability that week. As I plan on keeping this truck a veeeerrrrrrry long time. Thanks for the info guys. And Heatsroked thanks for the help the other day. Things are great so far. I will be making a small towing venture this weekend we'll see how she does. No hills on this trip but I should be able to get a feel for it. Thanks a lot!!!!!!
Fire Rooster
Old May 14, 2004 | 12:34 PM
HeatStroked
Sure Rooster, hope everything turned out to your satisfaction!
FYI: Thanks for the breakfast Burrito! I'm sure Charmin stock went up this week!
Old May 14, 2004 | 04:41 PM
Mil1ion's Avatar
Mil1ion
Due to the hostile attitude shown by some that posted here => Thread closed .
Posts that did not follow guidelines removed.
I think you are
Perhaps you will answer me ?
Nice Work Truck
Nov 28, 2009 11:13 PM
metalbender
Oil & Lubrication
Apr 26, 2008 12:36 PM
Fire Rooster
160
Feb 3, 2005 02:44 PM
Fire Rooster
Apr 26, 2004 10:26 PM
fsnco1
Modular V10 (6.8l)
Jan 20, 2003 01:27 AM
