Please Help Me Stop the Cab from Sinking!
Old May 11, 2004 | 03:38 PM
webly's Avatar
webly
Guys,
I've been trying to fix all the problems with my '75 F-250 caused by the cab mounts rusting away and taking half of the floor pans with them. Symptoms so far have included the clutch rod needing lengthening, the steering column upper bearing breaking and now the windshield is cracking! I know these are all symptoms of the real problem and just addressing them won't fix the cab sinking SO... I need help once again. While some friends down south search for a replacement cab (I haven't found a Wisconsin replacement cab that isn't almost as bad) there was a temporary cure mentioned by "73Custom" that involved putting a board between the frame and the cab bottom.
Marty... it seems you must have experienced similar problems and have answered in the past; so I'm asking for help one more time. Do I just lift the cab up (4x4 through the doors and a chain lift), lay a 2x6 on the frame and lower it back down; or is there more to it? I know you mentioned that this is a very temporary fix, but that's what I need right now. I'm trying to keep this baby going until I can get at the body problems. Mechanically it's fine!
Thanks in advance
Webly
Old May 11, 2004 | 03:51 PM
Mil1ion's Avatar
Mil1ion
Welcome to FTE!
This is more of a structural/bodyshop question.
This thread may end up there so you will get the best info for the project.
Old May 11, 2004 | 04:31 PM
yukon_bluenose's Avatar
yukon_bluenose
may i suggest a thick pad of rubber it being maybe old strips of conveyor belts.they will serve asa lift and also as a vibration dampener
Old May 11, 2004 | 05:00 PM
snowfighter's Avatar
snowfighter
I have done the board between the cab and frame I used a porta power to lift the cab from the frame. I then ran screws from inside the cab into the board good for a temporary fix.
COWBOYBUCK
Jan 23, 2015 06:32 PM
webly
1983 - 2012 Ranger & B-Series
15
Jul 12, 2009 12:42 AM
FLgargoyle
21
Jan 29, 2006 08:01 AM
webly
Jul 24, 2005 08:46 PM
FrayedSanity
Dec 26, 2002 08:08 PM
