General Automotive Discussion
HELP! engine/plug size?
Old Apr 30, 2004 | 10:43 AM
xminust's Avatar
xminust
Hey all - another new truck owner here...trying to figure out what size engine I have.
The engine is NOT Original...Here's what I know:
1. 75 Ford F-100 - (vin reads that the orignal was a 302)
2. Edelbrock Heads, 4-barrel Edelbrock carb, Headers, electronic ignition, not sure of the firing order.
3. Autolite AP-45 plugs currently in the truck- this is my stongest clue that the engine is not a 302 - my local auto parts store gave me AP-25 plugs for replacements, and insisted that's what should go in a 302. the AP-25 threads are much smaller than the 45's.
4. I've been replacing iginition parts slowly over the last few weeks, and have installed a starter that I got assuming it is a 302 - and it works great...what other engines would this starter work on?
5. I can get the truck to crank just fine, but it won't turn over. I'm sure I have some mismatched ignition parts - cap, rotor, coil, whatever.
thanks for any insight you can provide.
Is there an ID code on the engine block? Or can you call Edelbrock with a part number from the heads to get more information?
thanks!!
Chris
Old Apr 30, 2004 | 02:54 PM
Icicle's Avatar
Icicle
Count the bolts on the valve cover and repost.....for even more info pull the starter and post the stamped code thats underneath it
Old Apr 30, 2004 | 03:43 PM
xminust's Avatar
xminust
5 bolts
there are 5 bolts...and where exactly do I look for the stamp under the starter? I have replaced the starter, and casually looked, but didn't see anything
thanks!
chris
drexer13
Oct 21, 2013 08:53 PM
holdtyte
Sep 9, 2012 10:47 PM
The Ledge93
Oct 16, 2011 07:04 PM
earlybroncoboy
May 6, 2007 09:24 PM
79f150TX
16
Dec 11, 2003 07:23 PM
